1974 dt250a head gasket orientation
- Wbsterritt
1974 dt250a head gasket orientation was created by Wbsterritt
The new cylinder head gasket for my dt250a appears to have an "UP/DOWN" orientation to it. I see no mention of it anywhere in the service manual. Which side faces "UP" if anyone knows or if it even matters? Thanks.
30 Dec 2025 19:57
- pabdt
Replied by pabdt on topic 1974 dt250a head gasket orientation
Ridge Up.
LOL, this is not in the Yamaha manual I know of. A similar setup is we used to O-RING V8 engine heads to keep from blowing gaskets under extreme boost and detonation. Want to say was a 0.030" grove. Would do this by milling out a grove in the head for an o-ring type gasket to seat in, then put slightly less torque on exhaust heads bolts so when and if she blew, went out the lower side.
In the case of the Yamaha, I'm thinking it must form a firewall to keep combustion from escaping.
Hope that helps. BTW, this is my opinion on the matter. I have not read this in Yamaha docs.
Reminds me also, I reused a few gaskets. i guess if you turn them, you get a fresh side. haha.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- automan
Replied by automan on topic 1974 dt250a head gasket orientation
Either way.
Forms 3 barriers when compressed.
Do not anneal!
Do not anneal!
The following user(s) Liked this Post: Wbsterritt
31 Dec 2025 01:05
- Wbsterritt
Replied by Wbsterritt on topic 1974 dt250a head gasket orientation
Thanks! I was pretty sure it didn't matter due to the fact it isn't mentioned anywhere in the manual but I thought I'd ask all the "experts" on this site. Thanks again.
31 Dec 2025 05:00
Replied by MarkT on topic 1974 dt250a head gasket orientation
Ridge up
31 Dec 2025 08:45
It does matter which way it is installed. Standard rule of thumb for gaskets without any installation markings is ridges or markings face up.
Snap rings are another item that manuals often don't specify how to install. But there is definitely a correct orientation of the sharp edge for best results.
The following user(s) Liked this Post: Snglsmkr, AirborneSilva, Ht1kid, Wbsterritt
31 Dec 2025 09:26
