Autolube Kit from YAMBITS
  • Snowman
  • Snowman's Avatar Topic Author
Autolube Kit from YAMBITS was created by Snowman
Greeting from Canberra Australia,
Can anyone recommend (or not recommend) an Autolube rebuild Kit from YAMBITS for a DT250A.
I am just looking at rebuilding my pump which is not working. It was sitting for unused for 30years, worked a bit initially but now not pumping at all.
I will see if I can check the one-way valve first.
Regards
08 Jun 2025 18:31 #1
Replied by Enduro nut on topic Autolube Kit from YAMBITS
I would recommend them. I bought one for my 73 RT360 from them and everything matched up spot on. I think you will have an extra seal left over if I remember correctly. I think years 68-73 have 1 of the seals that's smaller/bigger than the 74+ years but don't quote me on that.
08 Jun 2025 21:22 #2
  • Snowman
Replied by Snowman on topic Autolube Kit from YAMBITS
Thanks for that, yes I noticed there were four seals in the Kit but only three in the pump!
08 Jun 2025 22:19 #3
Replied by Gr8uncleal on topic Autolube Kit from YAMBITS
I would just buy original Yamaha seals via your local dealer, they are still available.
08 Jun 2025 22:34 #4
Replied by Tinkicker on topic Autolube Kit from YAMBITS
I used the yambits kit on both big blue and  little yeller without any problems.  IIRC you have to buy the check valve ball and spring in an inexpensive separate kit.  Do NOT remove the large black plug from the end of the housing...
Last edit: 09 Jun 2025 01:16 by Tinkicker.
09 Jun 2025 01:12 #5
