Engine compression
Replied by MarkT on topic Engine compression
Even with the check valve in the end of the hose, the accuracy on small singles can be significantly affected.
The hose volume still makes a difference and a standard schrader valve will definitely reduce the pressure the gauge sees from the very short duration low volume "pulse" of pressure from a small displacement piston. (Getting help to push the bike fast in first gear to spin the engine faster than the kick starter can overcome some of this)
And yes, the best use for the compression gauge is "comparison" on the same engine.
- automan
Replied by automan on topic Engine compression
So that gauge pictured has 2 Schrader valves?
One inside base of gauge and 1 on side for relief?
Something does not add up.
23 Nov 2025 05:23
#42
- Tom P
Replied by Tom P on topic Engine compression
No. As I wrote, it has a Shrader valve in the gauge base BUT the fitting in the spark plug hole is open.
23 Nov 2025 11:58
#43
Replied by RT325 on topic Engine compression
My foot on the Kickstart tells me exactly how good the compression is. But I have a genuine yamaha compression gauge I'll post a pic of if I can--my google photo free thing is full. Might start using Imgur.
The following user(s) Liked this Post: MarkT, Tom P
23 Nov 2025 12:36
#44
- automan
So toss it. Why waste time shortening hoses and mickey mouse crap.
That Shrader valve must have a very light spring on it and must be flush to combustion chamber.
c
c
24 Nov 2025 03:44
#45
- Tom P
I found a solution for a cheap compression tester that gives me assurance that my bike is at least is 120 PSI, so why toss it? I don't test compression every day, only have one bike, and it gives me a baseline, so in the future I'll know if it drops. I like turning lemons into lemonade.
The following user(s) Liked this Post: MarkT, Gr8uncleal, Ht1kid
24 Nov 2025 08:09
#46
Here's my Yamaha comp tester if you can stop it i the first second. 25psi & barely dragged itself along haha. Ignore the painful video. I've run out of room on google photos so i'll do a short video of the yamaha tester in its box & post that later.
The following user(s) Liked this Post: Schu, Ht1kid, Pete-RT1
27 Nov 2025 20:12
#47
Here's my yamaha tester & my carb ballancing vacuum gauges plus monoshock test/inflating gauge. Things i don't use much anymore. In the video of the gauges you can hear a bike going hard out. Just some random on the main highway about half a mile from me.
www.youtube.com/shorts/M9hNJeCzkgo
The following user(s) Liked this Post: Schu, Ht1kid, pahiker
