Engine compression
Replied by MarkT on topic Engine compression
I have heard of a random washer falling out and getting lost when cylinder was reconditioned... the one I remember the machine shop used one of those heated high pressure wash cabinets like a big dishwasher for engine parts.
I don't remember if it was this forum or the old one... but someone also thought the washers were missing and added new ones... a mistake discovered when they either stripped a cylinder nut or noticed there weren't many threads showing on the studs... can't remember, it was a long time ago.
The following user(s) Liked this Post: 512_Newbie
31 Mar 2025 15:48
#31
Replied by RT325 on topic Engine compression
Ahh--ok, things to be careful of.
31 Mar 2025 16:09
#32
- 512_Newbie
Replied by 512_Newbie on topic Engine compression
In my defense, you can't really see the pressed-in washer.
So I carefully fitted the aluminum bolts and could see that they are in place and secure the cylinder. So the washers seems to be in...
I had the same problem with my Royal Enfield, it was important that they were special aluminum washers which you should not forget. Hence the question.
01 Apr 2025 02:14
#33
Royal Enfield-- umm--its 60 years since I worked on my 350 bullet. Where I worked back then we were RE agents but don't think I ever saw one in the shop except mine. I used every new gasket set we had jn stock as I had it in bits almost weekly. It was my first motocross bike but kept throwing me off then jumping on me just to teach me a lesson haha. I Won the war & sold it to my mate.
The following user(s) Liked this Post: Ht1kid, Sneezles61, 512_Newbie
- 512_Newbie
I imagine an Enfield as a motocross is quite heavy and sluggish, but a nice experience you describe!
I converted my 500 to a chopper and after some optimisation don't really have any technical problems. But I also don't ride very much and certainly more comfortably than you did off-road. Did you have any thermal problems? I also fitted a larger oil pump, as the original one is probably quite small and can cause overheating.
If you are interested, here is a short video of mine
www.instagram.com/p/C9PbpsjIMyL/
I have now reassembled everything and was able to start it for the first time yesterday.
I also replaced the ignition (breaker contact, capacitor, ignition coil) and checked the oil pump for minimum stroke. Also replaced the diaphragm inlet. So I should have replaced all wearing parts as a precaution.
It started on the first try!
Im happy with the new paint, hope it lasts a long time without flaking off.
Here some photos of the final result. PS: After the video, I set the pilot air screw to the factory setting. This made the engine run better
imgur.com/a/Q3r83RS
I have now filled up with 1:100. How long should I take it easy on the engine before I can turn the gas tap properly?
I will retighten the cylinder head as described.
imgur.com/a/Q3r83RS
The following user(s) Liked this Post: Ht1kid, Tom P, pahiker
- Tom P
Replied by Tom P on topic Engine compression
A while back I checked the compression on my CT-1, and with my cheap tester it only came up to around 70 PSI. I knew that probably wasn't accurate, and likely because of the 14" 1/4" ID rubber hose from the spark plug hole to the meter, where the Schrader valve is. From what I understand, some testers have a Schrader valve in the fitting that goes into the spark plug hole, and with those I don't think it would matter as much how long the hose was.
So today I tried an experiment. I cut the hose out leaving about an inch on each fitting, and joined it back together with a 3/16" ID brass barb fitting. A 1/4" barb union would have fit the hose better, but I used hose clamps anyway, and I thought the smaller fitting would reduce the air volume between the spark plug hole and the meter. Well, it worked! With one kick I got over 90 psi, then after about six kicks it leveled out at 110 PSI.
That was with a cold cylinder, so I let it warm up, then tried it again. It actually dropped a little bit, to just over 105 psi, but then my neighbor came over and gave me a push with the bike in second gear, and it went up to 115 PSI. One cool thing about this setup is that it's easy to screw in without removing the tank.
JFY
imgur.com/a/s8zImAY
Update: I just cut the hoses off a bit more and also shortened the barbs on the union. Now I can get 120 PSI just kicking it cold. I still don't know if that's completely accurate, but it gives me a good baseline, and it sure is better than the 70 PSI I was getting using the full hose!
imgur.com/a/4UgT6eS
JFY
imgur.com/a/s8zImAY
imgur.com/a/4UgT6eS
- automan
Replied by automan on topic Engine compression
bit confused here, but doesn't that type of gauge have the valve in the 14mm cyl. fitting?
- Tom P
"but doesn't that type of gauge have the valve in the 14mm cyl. fitting?"
Some do, but mine does not. Mine cheap unit (was only $25) has the Shrader valve in the gauge, and came with 4 fittings (with no internal valves) to fit various spark plug holes. Then there was a 14" long 1/4" ID hose connecting the open fitting to the gauge/valve. For use with a higher volume car engine cylinder, it may work well, but there was far too much compressible air volume inside the hose to work with the low volume of a CT-1 cylinder. My modification has removed the majority the compressible air volume outside the cylinder, but not entirely. Going from 70 PSI with the long hose, to 120 PSI with the short hose, which is probably still a bit lower than what it really is IMHO.
Just to clarify; I didn't post a pic of the unit as it came with the long hose, but in-between the 2 silver hose clamps, there was about 12" more of hose that I cut out. The Shrader valve is in the lug just above the silver knurls on the gauge, and the internal ID of the remaining hose ends is very small, due to a 3/16" brass union.
imgur.com/a/4UgT6eS
imgur.com/a/4UgT6eS
The following user(s) Liked this Post: Tinker man
- Tinker man
Replied by Tinker man on topic Engine compression
Good afternoon
Interesting observation about the location of the valve. I too have one of these cheap units from eBay. Used previously on old car engines, more to compare cylinder compression across a full block.
I have tested my RT1 project with this tester to see if there was enough compression to try to start it at some point. I registered approx 105 psi. I may try shortening the tube as you did just to see if I get similar results of raised pressure. Thanks for pointing this out.
Cheers, ian
Cheers, ian
I love taking stuff to bits - putting back together is another thing altogether.
21 Nov 2025 08:34
#39
- Tom P
Yep, these cheap testers are good to compare cylinder compression on a multi cylinder engine, but for accuracy you really need that check valve to be in the spark plug hole. If you shorten the hose I'll guarantee you'll find a difference.
21 Nov 2025 11:08
#40
