1974 dt125 to 175
- LongStride
Replied by LongStride on topic 1974 dt125 to 175
don't think the electric start is strong enough to spin it over with the higher compression, the boost in mid-range power sure adds to the smile factor
2ET703 Central Texas
- Enduro Rod
Replied by Enduro Rod on topic 1974 dt125 to 175
My thoughts are that the compression ratio on the 175 a little lower than the 125 according to specs just more piston mass. I can slightly pull the compression release lever and hit the starter button
07 Jan 2024 08:52
#22
- Pete-RT1
Replied by Pete-RT1 on topic 1974 dt125 to 175
Member here AGOP has an AT1-E with a CT1 top end and it won't crank on the electric starter, hot or cold.
I seem to recall someone saying theirs does with the engine hot, guess you'll just have to wait and see.
175s certainly have a lot more go than the 125s
Yamaha CT3 (in bits)
07 Jan 2024 09:40
#23
Replied by Gr8uncleal on topic 1974 dt125 to 175
"I can slightly pull the compression release lever and hit the starter button"
Have you fitted an aftermarket compression release valve in the second spark plug hole?
07 Jan 2024 10:03
#24
- Enduro Rod
Not on this bike but others. The kit is sold on eBay. It’s straight
Forward. What is your thoughts? Sorry about typing. Not sure
Why it does it Half the time about .
Which kit and does it fit 14mm (M14) spark plug thread?
07 Jan 2024 12:08
#26
- Enduro Rod
The kit from bultaco east. Mine is 14mm 3/4 reach so you leave the
Spacer out.
Spacer out.
07 Jan 2024 12:53
#27
07 Jan 2024 13:07
#28
Replied by RT325 on topic 1974 dt125 to 175
I'm a couple of pages behind, but i run an early AG175 head on a TY175 cylinder & doesn't look too out of place.
Maybe i'm just used to seeing it as it is.
Ag head is only a CT3 head.
Mind you looks aren't everything [so someone said lol] & reffering to my bike in this instance.
Sorry if ya can't unsee it now.
photos.app.goo.gl/waxr9fZrPdBg6Zya7
photos.app.goo.gl/w1cWcwNN2CMVKPNM9
photos.app.goo.gl/9qYiRTmRzK4Sti566
07 Jan 2024 18:02
#29
