1974 dt125 to 175
Replied by MarkT on topic 1974 dt125 to 175
Check recent post from DVM... I thinks he's selling what you want. (Not sure why you want a CT3 cylinder when you already have what you said was a good DT175 cylinder?)
Anyway, post was something like "members near Orange County". DVM is a great guy and has one of the best running CT3's I've ever ridden. You can ask if he'll ship to you.
The following user(s) Liked this Post: DVM
06 Jan 2024 08:07
#11
- Enduro Rod
Replied by Enduro Rod on topic 1974 dt125 to 175
Thanks mark the reason is because a ct3 cylinder and head to match like you suggested. Is a dt175 piston compatible with the ct3 porting. Thanks for your help
06 Jan 2024 08:24
#12
- Enduro Rod
What I don’t like about the Dt175 cylinder is that the tach drive cable
Isn’t clearanced in the cylinder and head. Thanks for your time
thing
thing
06 Jan 2024 08:44
#13
If there is no tach cable fin clearancing then I'm pretty sure you do not have a DT175 cylinder. The 74 cylinder definitely had clearancing.
06 Jan 2024 10:07
#14
- Enduro Rod
Sorry about typing. Tachometer comes out on a major different angle
On the dt175 than the dt 125. I think the ct3 comes out just like the
74 dt125. I seen the bike it came off of
06 Jan 2024 10:18
#15
Replied by Ht1kid on topic 1974 dt125 to 175
Can you post some pictures that would help you have to use a third party Imgur, google photos etc
06 Jan 2024 11:05
#16
- Enduro Rod
I don’t usually don’t usually do anything like this. I wouldn’t know
Post pics other than direct. Tried to change avatar and that doesn’t
Work ether. I will just get a ct3 cylinder. DVM doesn’t send so I will
The 125 runs great. Totally rebuilt. Does the 175 have a lot more
Power than the 125 or a waist of money? Thanks
06 Jan 2024 13:11
#17
- DVM
Replied by DVM on topic 1974 dt125 to 175
The 175's have LOTS more power than the 125's! You would love the boost in power.
06 Jan 2024 13:52
#18
- Enduro Rod
Thanks that’s what makes it worth while! Will the electric start still
Turn the motor over? I have a AGM battery with double cca over
Stock! Thanks Rod
Stock! Thanks Rod
- DVM
I have seen 125's upgraded to 175's crank over with no problems but no guaranties.
DVM
DVM
06 Jan 2024 15:19
#20
