shift Cam question
Replied by RT325 on topic shift Cam question
If the return spring was crossed, [not pulled apart parallel as it should be [to sit correct across the eccentric screw & the piece of the change arm], then you'll have about 1/3 of the movement [guessing] of un-sprung lever travel.
That 'might' cause an issue for hooking over the next pin unless you lift the lever a little to hook over it to change the next gear.
The following user(s) Liked this Post: Digger65, Ht1kid
06 Nov 2023 23:44
#41
- Digger65
Replied by Digger65 on topic shift Cam question
imgur.com/a/WL8iZKd
..yes torsion spring indeed crossed
will get it together shortly and hopefully, finger xd
thanks all
will update shortly
thanks all
will update shortly
07 Nov 2023 05:36
#42
Replied by Ht1kid on topic shift Cam question
That should fix your problem.
07 Nov 2023 05:55
#43
Be "careful" that the spring doesn't bite you as they take no prisoners holding them straight & against their will.
- Digger65
imgur.com/a/zhrEUpH
seems legit
(for some reason link seems to flag a picture of a torsion spring as requiring 18 and over consent)
seems legit
- alnarv
Replied by alnarv on topic shift Cam question
Some reason the end of your crank and gear nut all chewed up? Looks like the clutch assy. may not have been seated properly?
08 Nov 2023 06:30
#46
Good spotting ALNARV. I can't imagine what could whiz around there to cause that. Does the alloy basket overlap there if the nut came loose Be interesting if motors could talk.
08 Nov 2023 13:30
#47
- Digger65
should have changed the nut out while i had it apart
next time..
all gears changing smooth now
glad i didnt have to split the cases
thinking a yearly winter strip down might be on the cards, casing polish new clutch next time, beaings and seals again
feel like, with everyone help here, have gained some understanding of the bike so thanks all
still getting somewhite smoke on start up, hesitation and a missfire but will keep at it am getting close now
cheers
all
next time..
cheers
all
The following user(s) Liked this Post: rsmith56
11 Nov 2023 14:20
#48
