shift Cam question
  • Digger65
  • Digger65's Avatar Topic Author
Replied by Digger65 on topic shift Cam question
thanks will check the manual for it now
16 Oct 2023 08:54 #11
  • Digger65
we are talking #17 on this schematic?
imgur.com/a/LLZAJur
don't recall touching that
but good to have somewhere to start
16 Oct 2023 08:58 #12
  • Digger65
ok not sure whats going on here
moved around on the splines but doesn't seem to make a difference
not a good one anyways
imgur.com/a/H6YCESw
16 Oct 2023 10:25 #13
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Replied by RT325 on topic shift Cam question
Got to turn one shaft whenever attempting to select gears to get dogs to locate.
So slightly turn the sprocket back n forth in that last video while moving the gear lever.
If everything is as it should be internally you'll feel it engage. Well, i guess if everything on the otherside is as it should be too--which is why i suggested turning the drum manually without linkage--while manipulating a sprocket or clutch shaft shaft back & forth, if the clutch is off the shaft.
The following user(s) Liked this Post: Digger65, Ht1kid
Last edit: 17 Oct 2023 03:41 by RT325.
16 Oct 2023 14:52 #14
  • Digger65
ok thanks again will have another go at it later in week
17 Oct 2023 03:30 #15
Replied by MarkT on topic shift Cam question
RT325 has covered it very well...  I'd like to add some pics from manual in case others might come along and view this thread
The 74-76 factory manual...  well..  it kind of SUCKS.  Not the best one at all.  Yamaha seems to sometimes leave out important details that were covered in earlier manuals or in later manuals...  sometimes not covered at all.
First, the shift linkage adjustment eccentric pin to center the "claw" in second gear.
Next, the goofy linkage at the shift lever simply needs to be installed in a straight line.
Speaking of that...  in your video of moving shift lever up and down, the lever hits the frame on the down movement well before the linkage moves all the way.
And most importantly, as said many times before the shafts must be spinning to shift.  No amount of frantic jiggling of the shift lever will get it to shift if trans shafts are not spinning.  (But I think you know that and perhaps a lot more than you're letting on?)
The following user(s) Liked this Post: Digger65, Ht1kid, Sneezles61
17 Oct 2023 08:05 #16
  • Digger65
thanks
yep, got it! shaft spinning
thanks for the manual pages upload
i will get the clutch off next go at it (need to check the crank oil seal and replae the o-ring for new anyways
thanks again
17 Oct 2023 09:14 #17
Replied by Ht1kid on topic shift Cam question
Be sure to take plenty of pictures of how your clutch is taken apart so you can reinstall it correctly
17 Oct 2023 15:24 #18
  • Digger65
to clarify
when its stated shaft must be spinning to select gears
is just this turning it by hand?
or is there a better method?
cheers again
D
18 Oct 2023 08:59 #19
Replied by Sneezles61 on topic shift Cam question
If your engine is in the bike and chain hooked up you can roll it.. without a chain move the drive sprocket by hand or even a socket that fits the nut… it just has to turn a bit to engage..
Sneezles61
18 Oct 2023 15:19 #20
