DT250A 1974 Gear Meter
- Emmenegger
DT250A 1974 Gear Meter was created by Emmenegger
Hi,
i have to change the Gear Meter (Front Brake)
How can i open the Screw under the Circlip?
Thanks!!
Thanks!!
29 Aug 2023 05:36
Replied by MarkT on topic DT250A 1974 Gear Meter
The following user(s) Liked this Post: Emmenegger
29 Aug 2023 06:01
- Emmenegger
Replied by Emmenegger on topic DT250A 1974 Gear Meter
I think there should be another tool. i tried to upload a picture on dropbox, hopefully it will work:
www.dropbox.com/scl/fi/qsg7hlcbxf32kssiw...7xrd5pxd3xgg6m8&dl=0
29 Aug 2023 06:14
You remove the circllp and the shim, special tabbed drive washer, and drive gear slide off.
To get the driven gear out (worm gear visible at top in your picture), you need the special socket and it's used down inside where the cable enters the hub.
Replied by RT325 on topic DT250A 1974 Gear Meter
You might get lucky with a wide screwdriver or shaped flat steel just across two slots if the center doesn't protrude up above level with slots.
I wouldn't recomend expanding circlip pliers but i'd probably try it--& break the tips off.
The following user(s) Liked this Post: MarkT, msavitt
29 Aug 2023 18:03
Replied by Ht1kid on topic DT250A 1974 Gear Meter
What I did when I was a teenager and no money I used needle nose pliers that fit in the slots be sure you clean the threads really good before you try it Worked for me
29 Aug 2023 18:24
I've never had the right socket either....
I've always found a way to get it done, often breaking things in the process.
29 Aug 2023 18:54
My best attempt was drilling two holes spaced just right in a piece of bar stock... then I hammered a couple of old allen wrenches that fit the slots in the nut through the holes and welded them in place. I had to cut the allens shorter and do a lot of grinding to get wrench to clear the back plate but worked ok. Loaned it out or lost it someplace. Worked best to get it loose. Then spun nut out with a punch or small screwdriver. Too clunky to get the next "bite".
Modified socket would be much better.
The following user(s) Liked this Post: Ht1kid, Emmenegger
29 Aug 2023 19:04
- nhsteve
Replied by nhsteve on topic DT250A 1974 Gear Meter
I modified a 12mm deep socket for this task. I put grease on the end of the socket, and carefully inserted it down into the (clean!) hole after removing the clip and cable. That left the impression of the 4 slots. I marked them on the side of the socket with a marker, and then ground off the in-between bit, leaving 4 tabs which with a bit of file work fit the slots in the speedo drive fitting fine. Gently eased it out with a ratchet, mine was not especially tight. Use heat if yours is.
The following user(s) Liked this Post: MarkT, Ht1kid, Emmenegger, Badrul
- Emmenegger
i just wanted to thank you all for your helpful suggestions!
I did the modification with a a 12mm deep socket and it worked just as it should!
07 Nov 2023 01:34
