DT400 Head Gasket reusable?
  • Clegg
  • Clegg's Avatar Topic Author
DT400 Head Gasket reusable? was created by Clegg
I pulled the head on my 75 DT400. Is the copper head gasket is reusable on this model?
Torque to 15 ft lbs cross pattern?
Last edit: 02 Aug 2023 13:13 by Clegg.
02 Aug 2023 13:08 #1
Replied by Tinkicker on topic DT400 Head Gasket reusable?
It is if you anneal it.  Heat it up with a blow torch till it takes on a very dull red glow and drop it in a bucket of water.
or if you have an infra red thermometer, heat it to 500C or so.
Last edit: 02 Aug 2023 13:19 by Tinkicker.
02 Aug 2023 13:17 #2
  • Clegg
Replied by Clegg on topic DT400 Head Gasket reusable?
I did that with my mapp gas torch.
Head bolt torque 15 ft lbs?
Last edit: 02 Aug 2023 13:24 by Clegg.
02 Aug 2023 13:23 #3
Dunno.  There is a full service manual for it, all ready to download in the tech library.
02 Aug 2023 13:50 #4
  • Clegg
For reference.
Looked in the manual under engine rebuild, but found the spec in the front few pages. 2.1-2.5 M-KG which converts to 15.189329 to 18.082 ft lbs.
The cylinder torque spec is 30 to 32 ft lbs.
Last edit: 02 Aug 2023 14:09 by Clegg.
02 Aug 2023 14:01 #5
Replied by msavitt on topic DT400 Head Gasket reusable?
8mm head bolts on many of my bikes are 15 ft lb in manual
I always anneal and reuse my head gaskets by heating.  But I don’t quench, so maybe I am not doing it properly?
02 Aug 2023 22:41 #6
Does not really matter either way.  I just like to clear anything hot away ASAP.  I have a tendency to find hot metal when I am not paying attention...
03 Aug 2023 02:13 #7
Replied by RT325 on topic DT400 Head Gasket reusable?
Yep was tought to go cherry red then in a bucket of water. Well think thats how i was tought so is how i've always done it. Works great. Oh, & i grease it on assembly too.
04 Aug 2023 05:08 #8
