1975 ct1-dt175 clutch problem
  • davewuf
  • davewuf's Avatar Topic Author
1975 ct1-dt175 clutch problem was created by davewuf
hi all,
      new to this,has the title states,when i tighten the nut on the clutch drum it locks with the basket,i’ve looked in the haynes manual and it says i should have a plain washer,bearing washer and another plain washer,which i am missing one plain washer,but even with the plain washer missing it’s like i don’t have enough room at the end of the shaft to put the locking tab on to safely engage with the splines,any help would greatly be appreciated.
24 Jan 2023 06:54 #1
Replied by Ht1kid on topic 1975 ct1-dt175 clutch problem
Greetings from Tennessee
24 Jan 2023 07:25 #2
  • davewuf
Replied by davewuf on topic 1975 ct1-dt175 clutch problem
thanks for the welcome
24 Jan 2023 07:36 #3
Replied by Pete-RT1 on topic 1975 ct1-dt175 clutch problem
Have a look at the vin number on your engine and let us know what model we’re talking about.
yamaha-enduros.com/index.php/175-cc-vin-numbers
On the CT1 there are a couple of thrust washers that go onto the clutch assembly first #18 and 19, often the back one slips down on assembly and stops the collar #17 seating fully on.
Yamaha CT3 (in bits)
24 Jan 2023 15:35 #4
Replied by MarkT on topic 1975 ct1-dt175 clutch problem
Yes, somewhat important to know what you have.  If it's a UK/Euro model, it could have a "CT" VIN and be a 1974 or 1975 model more equivalent to the 1974-75 US DT175 than than the earlier US CT Series.
yamaha-enduros.com/index.php/uk-vin-information
Last edit: 24 Jan 2023 15:53 by MarkT.
24 Jan 2023 15:53 #5
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic 1975 ct1-dt175 clutch problem
If UK/Euro model, there is likely an asterisk at the beginning and end of the frame number.
24 Jan 2023 23:46 #6
  • davewuf
hi
sorry for the late reply,the vin is,*ct1-311098*,it is missing a thrust washer assuming this is the right clutch,i will try to upload some pictures when i can figure how to do it,can anyone point me in the right direction to a diagram of the clutch and part numbers,thanks to this forum i’ve found out 74/75/76 clutches are not the same
25 Jan 2023 02:29 #7
  • davewuf
forgot to mention it’s a uk bike
25 Jan 2023 02:30 #8
  • Gr8uncleal
Check out post #2 from MarkT on this thread regarding UK VINs.
Best thing to do is to try and find an original parts list for your bike - fleabay is good for this, although you might find you end up buying one from mainland Europe. An original Yamaha service manual is a good investment as well.
  The DeeTee - Vintage Enduro Discussions (yamaha-enduros.com)
25 Jan 2023 03:55 #9
