Ignition problems
- Turbotim
Ignition problems was created by Turbotim
Hi all My beloved dt 175 1976 C still not running...
please see below video, ive added a picture to show the
condition of my stater cheers guysHi all My beloved dt 175 1976 C still not running...
Attachment not found
23 Oct 2022 07:07
Replied by MarkT on topic Ignition problems
You need to upload video to Vimeo or YouTube and then put link here.
23 Oct 2022 07:15
- Turbotim
Replied by Turbotim on topic Ignition problems
Sorry my mistake..please excuse other videos its my
young nephew videos im helping him with..
that should be the link...
23 Oct 2022 07:38
It's not as complicated as it may seem.
That ground wire you're talking about on diagram crosses over the wire to ignition coil. It does not connect to it. It's just a chassis ground point... possibly the one on the ignition coil mounting bolt.
You could remove every single wire from the bike and run one wire from points (Black coming out of stator) to ignition coil and get spark. Super simple. And in fact, sometimes disconnecting stator and coil from harness and running a jumper wire from stator to coil is a good way to troubleshoot.
The black/white wires that go to switches simply short the black wire between stator and coil to ground. The component within the blue circle are on the stator. The red line is the single wire needed for spark... and you can see the switch teed in that grounds that wire to kill spark. (You have two kill switches... either just shorts the primary stator wire to ground to kill spark)
The following user(s) Liked this Post: Badger52, Ht1kid
23 Oct 2022 08:43
- Turbotim
Brilliant il remove all wires except one black one going direct
to coil pack and see if I get a spark... the stator has had
New points new condenser and rewound all 3 coils... so
im not sure what could be wrong with it??
Will report back after trying above
23 Oct 2022 08:59
- Turbotim
So still no spark, stator is refurbished, not sure what
else to do?
[attachment=56325]IMG-20221019-WA0004.jpeg[/https://youtu.be/zrHCeOW0kwA]
else to do?
23 Oct 2022 10:42
Connect black wire to ohmmeter on Rx1 scale. Points closed should be zero resistance to ground.
Points open should be between 1 and 2 ohms to ground.
23 Oct 2022 10:51
- Turbotim
Take the flywheel off or can I just hook it off black wire coming out of the stator...apologies il not good at electronics
23 Oct 2022 11:06
- Turbotim
23 Oct 2022 11:20
Congratulations!
I tried to explain already. Look at diagram I posted. Kill switches simply tee into wire to coil from stator and switch to ground. With switch open, engine runs. (Switch in diagram is open) When contacts in switch close, the circuit is grounded and no spark.
23 Oct 2022 11:44
