76 DT400 flywheel nut
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic 76 DT400 flywheel nut
My "rattle gun" is just a cheap Harborfreight gun, I can put lug nuts on with it but then it wont take that same nut off.  Can't remember it's max torque rating but I don't plan on putting it's max torque on it, just see if I can move it a bit more and pray - a lot
The following user(s) Liked this Post: RT325, Tom P
20 Jul 2022 02:31 #21
  • AirborneSilva
  • Platinum Member
  • Platinum Member
We have success!!!  With the cordless impact gun I gave it a quick three shots, with a piece of tape on the socket to see how far it moved, connected gas and battery, three kicks later she came to life.  The timing is only between 2.5 and 2.6 but after three hours of trying to get the 2.9 I'm going to call it good for now.  Thank all of you for your input and encouragement!
The following user(s) Liked this Post: Gr8uncleal, Andy L, Sneezles61, Tom P
20 Jul 2022 06:35 #22
Replied by Tom P on topic 76 DT400 flywheel nut
Glad it worked out!
By the way, my cordless rattle gun isn't very expensive either, but it will break loose lug nuts torqued to 140 ft lb. However, as we've found out, if you're careful you can use them to torque the flywheel and clutch basket on these Yamahas.
The following user(s) Liked this Post: RT325, AirborneSilva
20 Jul 2022 06:51 #23
