76 DT400 flywheel nut
  • AirborneSilva
  • Platinum Member
  • Platinum Member
76 DT400 flywheel nut was created by AirborneSilva
Realistically how much torque can I put on the flywheel nut?  according to the manual it says 650 inch lbs (53.33 ft. lbs), but how much further can I safely go?  Due to a bonehead mistake I made my Vape flywheel spun on the crank so it wont stay in time.  I've lapped the flywheel and crank to remove any burs that it had but now I want to try and keep it from spinning.  Thanks for helping a brother out, hopefully I can get this going, again! Tony
18 Jul 2022 09:34 #1
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic 76 DT400 flywheel nut
Would 65 lbs be too much?
18 Jul 2022 17:16 #2
Replied by Tom P on topic 76 DT400 flywheel nut
I'm not an expert on this at all, but when I put my flywheel on, I just hung on to the flywheel with my hand and torqued down the nut with a cordless impact driver. I put a thin piece of tape on the socket so I could see how much it was moving, and just used my own judgment. A few months later when I had the cover off, I torqued it down a little bit more just to be safe.
I basically did the same thing on the other side with the clutch basket nut, and primary gear nut.
But again, I'm no expert on this... but I did stay at a Holiday Inn once.
18 Jul 2022 17:31 #3
Replied by Buggin on topic 76 DT400 flywheel nut
I wonder if a tiny bit of locktite on just the maiting surfaces (not threads) and using the proper torque would work? I would not want to strip or deform the crank threads.
1976 Dt400
1985 RZ500
2001 Xr650L
18 Jul 2022 22:55 #4
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thanks Tom, you're a brave man but in my case what's the worst that can happen, I guess if I stripped it I'd need a new crank.  Although your method has me worried since you didn't stay in a Holiday Inn Express
19 Jul 2022 02:08 #5
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Wish I would have thought of that (or you mentioned it earlier), I fought the timing for the better part of three hours yesterday.  Every time I it on my 2.9 BTDC it would move when I tried to tighten it down.  I finally got it close, a little less than 2.9 so I'll see how it runs at that, if it will run at all.
19 Jul 2022 02:11 #6
Replied by Sneezles61 on topic 76 DT400 flywheel nut
Fingers crossed…
Sneezles61
19 Jul 2022 04:27 #7
Replied by RT325 on topic 76 DT400 flywheel nut
I'll win the prize for the roughest mechanic--well hell we're technicians nowdays!!. All my 360 cranks have been previously spun by others, [some look spun a few times] & made a mess. Couldn't do much except make them look best as i could. But i do them up super tight although i don't use a torque wrench i'm sorry to say. My pic, albeit years ago, is still how i do it.  Actually looking at that handle i would have had a pushbike seat tube as an extension on that for more leverage. Or likely a YG1 Landscout fork leg lol--true i tell ya. Luck maybe but never pulled the thread off the crank. Also i've never had one slip & take the crank key out & as i said, all my tapers are damaged. I 'did' run a TT250 with no key playing with more advance & never slipped, but was a perfect taper. Same with an IT200 using a pirate flywheel & needed to run without key to get the timing right--& all good. So--don't be afraid to tighten it super tight. I hope its not slipping during your tightening process. I've run out of ideas now.
Last edit: 19 Jul 2022 05:16 by RT325.
19 Jul 2022 05:13 #8
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thanks for the replies, guess I'll give it some more torque and see what happens.  The timing did slip a little when I got it to the point it's at now so it's a bit below the 2.9 but not over so I believe it should run and what a gigantic exercise in frustration and patience that was!  I didn't think about resting the holder (for a lack of better words), on the foot peg so maybe that would have made a difference instead of holding it with my left while I torqued it with my right, I'm sure that would have helped.
19 Jul 2022 06:28 #9
Replied by Andy_C on topic 76 DT400 flywheel nut
Sorry if this is a dumb question, but how can it spin when there is a key on the crank?
Or are you saying the nut came loose allowing the flywheel to move off the key?
I always just do flywheel nuts up as tight as I can and dont bother with a torque wrench - never had one come off yet.
Ex Yam DT400C, Triumph Trident 660, Triumph 865, Kawasaki KH 400
19 Jul 2022 07:52 #10
