DT400b oil tank window removal
- GaryDean
Replied by GaryDean on topic DT400b oil tank window removal
well I removed the window, I used a scalpel to break the paint n laquer seal around the rubber, and with not much pressure it popped inside the tank. however trying to get it out has proved impossible as the tank I did not realise is like a baffle in there that is the boxey bit of the tank, after an hr I gave in and left it in there.
now I wish I had gone the drilling route as it popped so easily.
new window fitted and tank back on bike and looks great. 1 more week and I can put polish on it
28 Jan 2022 07:25
#11
- Pedalcrazy
Replied by Pedalcrazy on topic DT400b oil tank window removal
Yeah I wish I would have chimed in on never pushing it in on purpose. Though I think it was RT1 Pete that had good luck doing that? I pushed one in once by accident and shook the tank until it was back at the window hole and grabbed it with needle nose pliers and yanked it out. It’s probably just me but I would never leave an obstruction in the tank for fear of blocking off the oil flow. You won’t know until it seizes. Maybe the baffles will prevent that? Anyway ride at your own risk.
28 Jan 2022 08:26
#12
- GaryDean
aye that did cross my mind, looking at the feed pipe, it has a half moon filter or sorts inside the tank so I assume its that shape in-case anything goes into the tank and blocks off flow, so I decided to button it up and fit the new window
28 Jan 2022 09:28
#13
- Sneezles61
Replied by Sneezles61 on topic DT400b oil tank window removal
Well, after yer sure the paint is fully cured... You'll be flipping it upside down and be able to grab the offending apparatus with long skinny nosed pliers? Tugging and cussing as it comes out the in port?
Sneezles61
Sneezles61
28 Jan 2022 14:23
#14
- DT175DOUG
Replied by DT175DOUG on topic DT400b oil tank window removal
Gary,
Can I ask where you ordered a new window from? I need one for my DT175.
Did you order part #360-21761-00-00 ?
31 Jan 2022 20:03
#15
- GaryDean
Hi
I got it from Yambits £15.00
it is under dt400b on his website
01 Feb 2022 00:52
#16
- DT175DOUG
Thanks Gary.
I found it.
I found it.
01 Feb 2022 05:45
#17
