'75 DT250-B No lights at all are working
  • spudmanDT250
  • spudmanDT250's Avatar Topic Author
Replied by spudmanDT250 on topic '75 DT250-B No lights at all are working
Thank you DEET.  I will try to source a lighting coil in the morning.  Just one question....when you say the destroyed lighting coil is likely the root cause of the problems I'm having, were you referring to the lighting issues or the engine missing/backfiring issue...or both?  I guess I don't know enough about how the lighting coil and source coil interact with each other to know if they are somehow connected in such a way as to make a destroyed lighting coil mess up how the engine runs.  Thanks in advance for your input; it is much appreciated.
09 Aug 2021 22:23 #51
Replied by RT325 on topic '75 DT250-B No lights at all are working
Is your crank key in one piece> only asking as i expanded the pic right up to see there the source coil earth end goes, but guess over into the lighting coil as no visible end earth. Anyway just the crank key question. Also--performance--i see the the stator plate on full retard in the slots which i'd thing is unlikely so worry about that & timing & points gap combination after you've fixed the lighting coil. Also tighten the flywheel good as can damage the crank key if not tight. Key is only for locating & the taper 'should' do the holding.
The following user(s) Liked this Post: spudmanDT250
10 Aug 2021 04:59 #52
Replied by DEET on topic '75 DT250-B No lights at all are working
Fix the obvious, then see what your symptoms are.
The following user(s) Liked this Post: RT325, spudmanDT250
10 Aug 2021 05:14 #53
  • spudmanDT250
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=303833704444&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • spudmanDT250
UPDATE:  Looking at the lighting coil on my bike, I have a Green/Red wire attached (soldered) to one end and a Green wire attached (soldered) to the other end.  In addition, there is a yellow wire coming out of the coil as well as a wire that leads over to the source coil...and I just can't quite see where exactly they are connected to the coil.
10 Aug 2021 08:38 #55
That is not the coil for your bike.
10 Aug 2021 09:41 #56
  • spudmanDT250
DEET.....which coil is not the coil for my bike...the one that I described that is on my bike now or the one on eBay that I linked to above?
10 Aug 2021 13:17 #57
eBay
10 Aug 2021 15:54 #58
Replied by Ht1kid on topic '75 DT250-B No lights at all are working
On post 45 it looks to me the solder joint is touching the flat spring on your points maybe grounding it out
10 Aug 2021 17:08 #59
  • spudmanDT250
OK...thanks.  Well, today was a somewhat productive day.  Several weeks back, I was made aware of a motorcycle salvage yard within "doable" driving distance from my home.  I went there today to search out a lighting coil and possibly an entire stator assembly with both coils intact.  To say I hit the jackpot is an understatement.  Unfortunately, I didn't have my flywheel puller along and only one of the many Yamaha DT engines there had the flywheel removed and the coil looked nothing like mine.The owner sent me home with another engine though that he thought might have what I needed. I looked up the engine number here:
www.cyclerestorer.com/pages/show_man_ser...&manufacturer=Yamaha
It came back as being from a 1977 DT250D.  I pulled the flywheel and took photos.  What you see in the attached photos are my current stator on the LEFT and the one from the '77 bike on the RIGHT.  My question....will this work with my engine (the entire stator or maybe just the lighting coil)?  The wire colors are NOT the same, nor is the plug at the end of the harness.  My harness has "Green/White", "Green/Red", "Yellow" and "Black" at the end of my harness, which is a 4-spade type plug.  The harness from the '77 stator has Yellow, Green/White, Black/White and a sky blue wire for the neutral switch all terminating in a different plug using pins instead of spades.  I know it's not identical, but was wondering if it might work with a simple change of harness plugs.  If not, I'll be making a trip back to the salvage yard with flywheel puller in hand to find a better (hopefully exact) match to my stator.  One more thing, and this may ultimately prove important...my engine's engine number plate has been ground away and I do not know with 100% certainty that I have a '75 DT250-B engine.  I completely forgot to mention this from the start, as I only remembered it this afternoon.  I didn't think it was overly important because my frame number corresponds to a '75, but I can see now that Yamaha made many small changes from year to year.  Thanks for any advice guys.
10 Aug 2021 17:10 #60
