green wire with yellow stripe
- hcdiiiga
green wire with yellow stripe was created by hcdiiiga
There is a green wire with a yellow stripe with a male connector which comes out the end of the wiring harness on the headlight end of the harness, I see the wire down at the the rear brake stop switch on the bike and wiring diagram, but I don't see where to connect it at the headight end, I don't see a green wire with a yellow stripe coming out of the main switch or the handlebar switches headlight or gauges.
- SKYDANCER46
Replied by SKYDANCER46 on topic green wire with yellow stripe
You don't say what bike but green with yellow strip usually is front brake light switch on front brake lever. Connects in headlight bucket area to main harness. Then that wire runs down to rear brake switch and joins the yellow wire at the bullet connector.
- hcdiiiga
Replied by hcdiiiga on topic green wire with yellow stripe
DT 3. I'll look again for the connection
03 May 2026 11:35
- SKYDANCER46
Should be a single wire coming out of main harness. There should be a brown wire too. Both connect to front brake light switch.
03 May 2026 11:48
Replied by Gr8uncleal on topic green wire with yellow stripe
The terminal on the end of the green/yellow wire coming from the main loom in the headlight shell should be a female bullet. Green/yellow and brown wires from the front brake light switch are both male (see link).
FRONT STOP SWITCH ASSY for Yamaha - order at CMSNL
03 May 2026 11:57
- hcdiiiga
Thanks to you both. I found the problem, the brake lever on this bike does not have the brake stop switch.
The following user(s) Liked this Post: Blackhat250, Snglsmkr
03 May 2026 12:35
