1974 DT125A Electric start will not work ,charging system not charging
For the starter to work, if you bridge the solenoid woth a heany screwdriver or something, it should sent 12 good volts down the light green "by memory" to the starter fields & should spin the motor. So long as you have a heavy red to one side of the solenoid from the battery. Plus a heavy earth from battery to frame. Motor mounts tight for a good earth & brushes under spring pressure. She should spin even without the rest of the system live.
Ok , reading back i see its not charging so must be running. Be good to get the starter operating as could indirectly be to do with why its not charging.
18 Jun 2021 03:15 #11
  • Yamadog1974
  • Yamadog1974's Avatar Topic Author
So as you know there`s an added shaft that has the cam lobe and timing advance on it..... And the manual doesn`t even go into how to pull it. It is a hairy Job at least...... I don`t want to mess up the points setting trying to avoid disturbing magneto if I can .Someone mentioned getting on Bike Bandit or similar that sells Yamaha parts . even the manual that has wiring schematic shows pigtail for DT125C says that DT125A/B similar .I`m not comfortable guessing. the only way I got it running was push stating it with fully charged battery. Once its warm kick start will work,but electric starter won`t itll try thats it. It`ll run till the batteries too weak feels like the fuel systems clogging up (which it was but is`nt now....rusty gas tank that i treated there`s still stray crap in )
18 Jun 2021 05:16 #12
