1974 DT125A Electric start will not work ,charging system not charging
- Yamadog1974
1974 DT125A Electric start will not work ,charging system not charging was created by Yamadog1974
1974 DT125A Electric start will not work ,charging system not charging. Here’s a couple new pics first one is online pic of a 1974 DT125A wiring harness , don’t know if they left exactly as it was ( no fuse holder) second pic is my configuration of same part and my guess as how to wire .
Last edit: 12 Jul 2021 11:06 by Yamadog1974. Reason: New pics new info first pic online 74 DT125A wiring harness …. Second pic my configuration of same one
16 Jun 2021 06:25
Replied by Gr8uncleal on topic 1974 DT125A Electric start will not work ,charging system not charging
First port of call for those problems is usually the brushes - check that they aren't worn down.
There is likely to be a service manual for your bike in the Tech Library (see top toolbar) and there will be troubleshooting procedures within that.
16 Jun 2021 06:55
- Yamadog1974
Replied by Yamadog1974 on topic 1974 DT125A Electric start will not work ,charging system not charging
when i got the bike the leads were not on a battery ........ not sure of positive leads if it has a pigtail that goes other than the starter relay. Regulator is in there somehow ,a picture of back connector from battery would sure help!
16 Jun 2021 08:18
- Sneezles61
Replied by Sneezles61 on topic 1974 DT125A Electric start will not work ,charging system not charging
Find yer bike in the library... Do study it's wiring... look at yers... study a bit more... There are things that cause issues... It really takes time to sort of stuff... I think you'll become a better person for taking the time to understand what makes it tick...
Sneezles61
Sneezles61
16 Jun 2021 19:37
- Yamadog1974
I really believe I have a wiring issue........ there is a guy here that has exact same bike ........ if he`d send me a pic of the battery lead and how the fuse and voltage regulator are plugged in..... I`m no electrician the wiring Diagram`s clear as MUD. the should show the actual wire harness, instead of roadmaps of color coded wires and symbols
17 Jun 2021 05:45
Replied by MarkT on topic 1974 DT125A Electric start will not work ,charging system not charging
The other thing you could do is take pictures of the wires and components you have questions about on your bike and post them here with the questions.
17 Jun 2021 06:06
Whilst you wait for photos, or if none are forthcoming, what you could do is put your Sherlock Holmes deerstalker on and try a little sleuthing.
The CMSNL website often has photos of parts, as well as the parts lists. For your bike, on the page for electrical items, they have photos of the battery leads and all the parts relevant to your wiring query.
Have a look at this and check that you have the correct positive battery lead, together with the starter solenoid that I THINK it connects to (I came to this conclusion from looking at the wiring diagram). The other part of the positive lead should connect to one end of the fuse holder, the other end of which should connect to the main harness.
Hope that this helps.
17 Jun 2021 06:25
- Yamadog1974
TY
17 Jun 2021 09:58
- Yamadog1974
I will try this ,Thanks
17 Jun 2021 09:59
- Sneezles61
How about just clear up yer schedule... grab the wiring schematic... sit a the table... an ice cold brew, and chase just ONE wire with a pencil... Starting at the generator... one wire at a time... relax... see where it ends up at...
I just rewired a trail 90... I have about 6 hours just reading the schematic... Then looking at the bike and the schematic... I am grateful to made this time investment...
Sneezles61
Sneezles61
17 Jun 2021 10:45
