kick start is stiff
kick start is stiff was created by sam
my dad gave me a 1975 Yamaha dt175 it took a little bit of work to get it started and then i put it away for about a year, i rolled it out and started it (i didn't have to do anything), when i was coming home from the track it was starting to get sluggish i didn't think much if it and thought it was a bad air filter and i parked it for that night the next morning the kick start was stiff i pulled of the head and didn't see anything wrong and i cleaned up the rings but it's still stiff (i tried purging the engine with oil) please help
18 Nov 2020 17:14 #1
Replied by MarkT on topic kick start is stiff
Is there oil in the transmission?
18 Nov 2020 18:39 #2
Replied by sam on topic kick start is stiff
yes there is.
19 Nov 2020 07:45 #3
Replied by mdscott on topic kick start is stiff
You mentioned the head was off and cleaned the rings, to get to the rings the cylinder will have to come off, was that done?
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
19 Nov 2020 08:04 #4
yes i did take of the cylinder sorry i don't say that.
19 Nov 2020 10:13 #5
Replied by RT325 on topic kick start is stiff
Will the motor turn easily using the magneto flywheel to turn it by hand.
19 Nov 2020 13:41 #6
I haven't got that deep into the engine but when i took the cylinder off the parts moved normally and didn't seem like they were binding
19 Nov 2020 21:09 #7
Replied by Rick C. on topic kick start is stiff
OK, Stop. Take pictures all around, and post them here.
We need to see.
19 Nov 2020 22:32 #8
Replied by Wessi on topic kick start is stiff
Remove the clutch cover and most likely you will see whats wrong.
20 Nov 2020 09:18 #9
hi guys i figured out what was wrong i needed a new crank bearing thank you guys for the help
21 Nov 2020 18:17 #10
