Airbox Grommet
  • Silo7
  • Silo7's Avatar Topic Author
Airbox Grommet was created by Silo7
Need the airbox grommet part number, left side. Grommet inserts into frame, post on airbox inserts into it. Tried multiple diagrams with none showing the part. Any help is greatly appreciated. 1976 DT 400.
24 May 2020 06:27 #1
Replied by Eazy-X on topic Airbox Grommet
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=111601928512&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by Gr8uncleal on topic Airbox Grommet
Original part number was 214-21746-00, now superseded to 90480-10091.
This point has been raised previously and I believe that the part numbers were obtained from a DT175 parts list.
Part is still available from Yamaha.
The following user(s) Liked this Post: MarkT, Pillsbury
24 May 2020 07:06 #3
Replied by MarkT on topic Airbox Grommet
24 May 2020 07:07 #4
  • Silo7
Replied by Silo7 on topic Airbox Grommet
That’s the location and function for sure but the 175 and older 360 use a thinner grommet, this 76 400 width is about 8mm. Hopefully the pics will help explain. Thank you, this is exact problem, but has to be different part number.
24 May 2020 07:12 #5
Replied by Makotosun on topic Airbox Grommet
Fixed the errant thread.
The following user(s) Liked this Post: Gr8uncleal, Silo7
24 May 2020 08:08 #6
Photos are attached of the one I bought as per the part number I quoted.
24 May 2020 08:11 #7
  • Silo7
Thank you
24 May 2020 08:52 #8
My bet is that it doesn't take a grommet with that wide metal bushing in the bracket.
I'd use a rubber sleeve over the pin.... like a piece of fuel line.
24 May 2020 09:44 #9
Fair point Mark.
So which part have Yamaha missed off the diagram then?
24 May 2020 09:48 #10
