1975 DT175 timing questions
  • GJVGC
  • GJVGC's Avatar Topic Author
Replied by GJVGC on topic 1975 DT175 timing questions
I removed the key switch and tested for continuity at the brown wire from under the key to the plug and it checked out but that may not mean the switch is good.
The other functions of the key switch work because I can turn the bike off with the key. And it won’t turn on with the key in the OFF position
Replace it?
Last edit: 01 Jul 2020 14:43 by GJVGC.
01 Jul 2020 13:23 #211
Replied by MarkT on topic 1975 DT175 timing questions
Switch legend in manual tells you what you need to know
With key OFF, the Black (B ) and Black/White (B/W) are connected.
With key ON, the Red (R) and Brown (Br) are connected.
(the dots connected by lines show you which wires connect.)
So with key on, you should have continuity between the Red and Brown switch wires.
Some switches are fairy easy to open and repair... if not, you'll need to replace.
Last edit: 01 Jul 2020 15:47 by MarkT.
01 Jul 2020 15:47 #212
  • GJVGC
Thanks again.
I took the switch off and it looks like wires soldered onto the switch, do the red and brown connect to each other somewhere inside the wiring cover? Not sure I would have the skill to fix the switch
Don’t have continuity from red to brown with the key ON
Are any of the aftermarket key switches any good?
Last edit: 01 Jul 2020 16:11 by GJVGC.
01 Jul 2020 16:01 #213
When you turn the key to on, the contacts inside the switch connect red to brown.
I'm not sure how else to say it. Some come apart easy and contacts can be cleaned/fixed. Without seeing what you have, it's hard to say.
01 Jul 2020 16:12 #214
  • GJVGC
Well!
We got light!
I took the key switch apart, sprayed some electric contact cleaner and cleaned up some of the contacts with a qtip and walllaaaaaaaa!!!
Now I have working neutral and brake lights!
Thanks mark!
Glad to have something to do during covid!
The following user(s) Liked this Post: 2fishkev, yamahahaha, JimA, Gr8uncleal
Last edit: 01 Jul 2020 18:04 by GJVGC.
01 Jul 2020 18:03 #215
Great job! Congratulations!!! :likey
The following user(s) Liked this Post: Gr8uncleal, GJVGC
01 Jul 2020 19:06 #216
  • GJVGC
Installed fly handle bars and new kdi repro grips. Looks and feels so much better.
I think the key switch is still faulty, when I move the bars the neutral will go on and off. Or is it a bad ground?
Last edit: 02 Jul 2020 13:04 by GJVGC.
02 Jul 2020 13:01 #217
Does the tail and brake light also go out when you turn the bars? Could be the ignition switch then
You could have a partially broken red or brown in the harness that makes and breaks connection when flexed.
02 Jul 2020 13:14 #218
Replied by Midlife Motor on topic 1975 DT175 timing questions
Thread of the Year 2020. Find something else wrong on the bike so we have something to read while we are supposed to be working.
The following user(s) Liked this Post: 2fishkev, GJVGC
02 Jul 2020 14:17 #219
  • GJVGC
Yup, the tail and brake lights also go out when I turn the bars.
Gonna remove the wiring “shield” to look at the wires.
Hahaha I don’t know about thread of the year.
But I sure am glad to have all the awesome help here.
I have to find a fix for the headlight. I’ve seen some use a later dt175 headlight unit?
Last edit: 02 Jul 2020 16:54 by GJVGC.
02 Jul 2020 16:50 #220
