1975 DT175 timing questions
Replied by MarkT on topic 1975 DT175 timing questions
If the brown at the bulb has continuity to the bucket but no power at the bulb, then you need to make sure brown is plugged into (key on) power in the bucket.
If it is, then maybe the socket or bulb is bad?
01 Jul 2020 00:07 #201
  • GJVGC
  • GJVGC's Avatar Topic Author
Replied by GJVGC on topic 1975 DT175 timing questions
Mark
How can I check the brown at the bucket is connected to key on power?
I think that’s my problem. I’m not getting any voltage at any of those browns I posted a picture of with the key ON nor at the bulb.
I swapped bulbs with the one off the high beam which I know was working. And made sure the bulb was making contact in the socket
Last edit: 01 Jul 2020 05:39 by GJVGC.
01 Jul 2020 05:38 #202
Do you have a voltmeter or test light? That's all you need to check if there's power.
Does the front brake light switch, horn, and rear brake light switch work? At least a couple of those run off that connector if I remember correctly. If nothing else works, check the fuse.
01 Jul 2020 06:53 #203
  • GJVGC
Yeah I checked with my voltmeter.
No voltage at any of those brown wires with the key ON.
Horn and brake lights are also not working.
Let me check the fuse. That should have been the first thing I checked lol
What’s size fuse should it be??
Last edit: 01 Jul 2020 07:19 by GJVGC.
01 Jul 2020 07:10 #204
Also make sure battery has power... pretty sure fuse is 10 amp on magneto models. It will say on it. Should be a spare in the holder if you're lucky.
01 Jul 2020 08:00 #205
  • GJVGC
Battery has 6.8 volts
Didn’t have a spare fuse unfortunately and the one on it says 10amp and looks fine but will replace to make sure
Last edit: 01 Jul 2020 08:34 by GJVGC.
01 Jul 2020 08:17 #206
Use your voltmeter to see if you have voltage on both ends of the fuse.
Then see if red wire at key has power. Then with key on, brown out of key should have power.
01 Jul 2020 09:09 #207
  • GJVGC
Getting 6 volts at each side of the fuse
Went under the tank to the key switch plug and the red wire has 6ish volts the brown wire has nothing with the key off or ON
I’m looking at the schematic to figure out where this brown wire gets its voltage from because I’m not getting any voltage at any of the points I have checked it at.
01 Jul 2020 09:37 #208
  • GJVGC
The red wire off the circled piece on the schematic has voltage, the brown does not with the key on the off and ON position
01 Jul 2020 09:39 #209
Red connects to brown in the key switch when key is on.
Sounds like problem is in the key switch.
01 Jul 2020 13:17 #210
