1978 DT175mx… engine won’t fit
  • MikeK-uk
  • MikeK-uk's Avatar Topic Author
1978 DT175mx… engine won’t fit was created by MikeK-uk
Firstly… Happy New Year to all.
I was going to reinstall my rebuilt engine but found that the upper rear engine mount with the bushes is approximately 3.5mm wider than the bracket.
The bushes were pressed in and are fully home and the brackets look straight.
Think I need to remove the bushes and get them machined or find shorter ones.
The old bushes were burnt and chiseled out when the cases were split.
How to remove them on a built engine? There doesn’t appear to be a space to use a blind puller.
Thanks,
Mike
01 Jan 2024 06:57 #1
Replied by LongStride on topic 1978 DT175mx… engine won’t fit
Cut off the 3.5 to fit?
2ET703 Central Texas
01 Jan 2024 09:45 #2
Replied by MarkT on topic 1978 DT175mx… engine won’t fit
Not enough info to know exactly what's going on but I'm pretty darn sure you won't get those bushings out without carefully cutting them out somehow.
Even if old bushings were bad, there is an internal spacer so bad bushings wouldn't cause the bracket to be bent in.  I have seen where the internal spacer was missing and the frame brackets are bent in slightly...  even though they look straight.  (The internal spacer sometimes gets badly rusted to the bolt and people leave them out on reassembly...  it really is needed with the rubber bushings)
You're talking about roughly 1/8" inch total or 1/16" per side.  A thick layer of powdercoat could cause that.  If frame was powdercoated I'd grind it off the inside of the brackets and/or bend the brackets slightly wider.
The following user(s) Liked this Post: Ht1kid, LongStride
01 Jan 2024 10:19 #3
Checked an engine I have out of the frame, mount measured 79mm total, 5.75mm sticking out on the drive sprocket side, 2.25mm sticking out on the kickstart side, might try running a nut down on a bolt in the mount to see if you can compress the bushing to make up the difference?
photos.app.goo.gl/cnYYPKRXJwjscyaBA
Last edit: 01 Jan 2024 10:45 by LongStride.
01 Jan 2024 10:41 #4
  • MikeK-uk
Replied by MikeK-uk on topic 1978 DT175mx… engine won’t fit
Thanks very much for the helpful replies… especially the measurement. My bushings measure 79.03mm, so seems like my brackets need “adjusting” (75.70mm).
The collar was fitted and it’s not powder coat that is the problem.
Really useful to know that I do not need to worry about the bushes and focus on the brackets.
Thank you - this is a great site!
Mike
01 Jan 2024 11:11 #5
Replied by RT325 on topic 1978 DT175mx… engine won’t fit
If you put a bolt through & it pulls up to spec then is the outer steel part right home in the case on both sides.
Center part if compresses 'being bonded rubber' will spring back untill the outer is right home.
Might be able to get a socket against the outer & give it a smack on both sides to bring them both in a little. Case will be stepped I guess so can only go to that step. Seems unlikely Yamaha would alter things like that between models but ya never know.
Last edit: 02 Jan 2024 15:26 by RT325.
01 Jan 2024 13:06 #6
Replied by Schu on topic 1978 DT175mx… engine won’t fit
I would stick a length of threaded stock thru both brackets and use hex nuts to draw your brackets in or out.
Last edit: 02 Jan 2024 14:55 by Schu.
02 Jan 2024 14:55 #7
  • MikeK-uk
Thanks very much for the responses and suggestions.Opened the bracket up as per Schu’s suggestion and engine now fitted.Now to complete the installation and do first start up after rebuild. Fingers crossed for that!Thanks again,Mike
The following user(s) Liked this Post: MarkT, RT325, Schu, Ht1kid, LongStride
09 Jan 2024 12:10 #8
