Triple Clamp Repair DT360
  • pabdt
  • pabdt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Triple Clamp Repair DT360 was created by pabdt
Was bored today, so decided to try and repair this clamp.  Its the original from my 360 which has another painted and installed TC at this time.
The original owner broke a bolt and then when he drilled out the new thread hole, it shifted too high.
Ground out the old bolt, then filled up bolt canal w/alum best I could.  Was afraid to hit with too much heat as I didn't want it to resemble a basket ball hoop.
I plan to put a heli-coil in at least one side, but I realized I don't have the center to center measurements.   If anyone has one handy,
would appreciate the measurement.  Though I guess just a equally centered hole like the other one should do it.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 17 May 2026 19:30 by pabdt.
17 May 2026 19:28 #1
Replied by DonTeeAus on topic Triple Clamp Repair DT360
Is that the mount holes for the plate that holds the main switch? If so I'd just bolt it in place with the good hole and use the other hole of the plate as a guide.
08 Jun 2026 20:49 #2
