1978 DT400 General Advice resurrecting solid bike
Replied by MarkT on topic 1978 DT400 General Advice resurrecting solid bike
It won't be the carb.
Common places are the intake manifold (cracked rubber or leaky gaskets), cylinder base gasket, or crankshaft seal.
You can build or buy a test kit to pressurize engine to about 5psi... spraying with soapy water will reveal leak.
Spraying gaskets/Manifold with something flammable with engine running is another way to find a leak. (A friend of mine uses a water hose on low flow to run a stream of water over suspected leak areas, I've never tried that... another friend uses a propane torch, not lit... and probes around with valve on... he says it revs up when leak is found. Never tried that either but I'd probably use it before water.)
If using flammable, do it outdoors in a well ventilated area... with a fire extinguisher handy just in case.
If no intake or base gasket leaks, most likely is ignition side crank seal, available from Yamaha, don't use aftermarket crank seals.
22 Apr 2023 09:37
#11
Replied by Ht1kid on topic 1978 DT400 General Advice resurrecting solid bike
I use the propane or mapp gas as MarkT says non lit I put a hose on the end and turn it on low I also use that trick on autos too
- RamadiRat
Replied by RamadiRat on topic 1978 DT400 General Advice resurrecting solid bike
Attached a video of the bike idling and revving. I could remove the carb and inspect the pilot jet again (I failed to take or post pictures) but I cleaned it pretty thoroughly with Berryman carb cleaner. I did see it's an .80. I tested for leaks with a propane torch and found nothing, however I did not test the crank seals - I assume they're behind the covers l/r sides.
With the air screw 2 turns out, she seems to stay lit with idle around 1400.. I still suspect an air leak because turning the air screw 1/2 turn either way seems to have NO affect
youtube.com/shorts/WTBQSuOcJz8?feature=share
Replied by RT325 on topic 1978 DT400 General Advice resurrecting solid bike
The old girl is Rich not Lean. Be good to hear it held wide open to hear if it limits out or clears to a point. But two turns out on the pilot screw & sounding "that" rich has me wondering if the pilot jet itself is right home in the body. Either 'that' or the slide needle jet is very worn & its sucking fuel past that at idle & not unheard of. Or needle misplaced in the slide but not sure if that's possible. Some carbs the needle could sit on top of the plate, where it should be under it & retained by the plate. I'd think yours would have a screwed on tower for the cable so can't go wrong.
Other thing 'is' i think your tacho is telling porkies & reading about double if that's possible. Also, #80 sounds big for a pilot jet. But if 'that's' what it is mean't to be then all good & wouldn't go reducing it just yet but look for other possibilities--like i mentioned above.
& another one--choke being held off the seat [unlikely & would be obvious with seal cap misplaced lifting it. Also in theory more choke fuel also gets more air so idle would rise & its not far off stalling [stalling rich] in the short vid.
But wait, there's more lol.--If i expand the pic looking in the top i can convince myself the needle jet isn't square on sighting it against the idle bleed hole. If that's the case has it missed the guide pin in the bottom. Not far enough out of line for that--but!!, is the main jet in there & all sitting right--thick brass flat washer i guess they must have to hold it all down.
That certainly isn't the sound of an air leak and "runaway" revs where it revs to the moon and doesn't shut off with key. Not even close.
My guess is your CDI is bad. Possibly the box, most likely the stator. You could try cleaning all the connections where the CDI box plugs in.
23 Apr 2023 15:46
#17
- msavitt
Replied by msavitt on topic 1978 DT400 General Advice resurrecting solid bike
I think the pilot jet in my 400 is ether a 50 or 55
23 Apr 2023 18:04
#18
I guess #50 could look like an 80--small numbers etched in. 80 would look big looking through, difference to a 50 would be quite visible.
23 Apr 2023 18:54
#19
- msavitt
Now I am confused and hope I didn't spread confusion and sorry if I did
I just looked into the manual and the Supplimental manual for the 78 DT400E from this site and it says pilot jet is 80.
Pilot get for my 360A listed as a #60 and I think I went up to a 62.5 or 65 to improve the you know what thing at light and steady throttle.
So 80 on a 400 seems to make more sense than me
24 Apr 2023 14:42
#20
