Testing CT2 source coil
  • robbnc
  • robbnc's Avatar Topic Author
Testing CT2 source coil was created by robbnc
I have no spark, new plug, new ignition coil, everything has a good ground. My source coil measures 2.8 ohms with points open. I can't seem to find the normal range for that reading listed anywhere, not even the manual.
Any ideas?
21 Mar 2026 15:36 #1
Replied by MarkT on topic Testing CT2 source coil
What is the reading with the points closed?
21 Mar 2026 15:41 #2
Replied by RT325 on topic Testing CT2 source coil
I'll look up the reading later in my yamaha literature  but sounds a bit high. Then again if your reading it off the black while still in with the plug coil primary then maybe explains it. OK nearest I can find is AT3F which is probably the same mag , says 2.1 ohms so close. Plug coil primary says 1.7. As I think MarkT asked does it show zero with points closed. I still use an old fashioned anologue meter which tells lies but I know where zero is by touching the leads together so start from there. OK sounds stupid‐-but.
The following user(s) Liked this Post: Jogar
Last edit: 21 Mar 2026 16:07 by RT325.
21 Mar 2026 15:57 #3
  • robbnc
Replied by robbnc on topic Testing CT2 source coil
I didn't check with points closed, I'll go do that.
21 Mar 2026 16:16 #4
  • robbnc
I was checking the black wire with the points plate out of the bike. I'm going to get a points closed measurement.
21 Mar 2026 16:18 #5
  • robbnc
Points closed reads 1.1
21 Mar 2026 16:26 #6
I'd better let Mark reply to that as I guess it should read zero as everything is earthed out when closed in my books. Sounds like ya using a digital meter but I dare say zero is zero. If you touch your leads together does it show zero.
21 Mar 2026 16:50 #7
  • robbnc
Yes it's digital and it does zero out with leads touched.
21 Mar 2026 16:52 #8
I'm outa here for the day but makes me think the points aren't making good contact. But just thinking. Points on probably 2 of my bikes dt1 at1 magneto are crusty at a quick glance * not been touched for about 30 maybe 40 years but never faulter or miss a beat. So I dunno anymore haha.
Last edit: 21 Mar 2026 17:24 by RT325.
21 Mar 2026 17:07 #9
Clean the point contacts.  Should be 0 ohms points closed.
Keep in mind that many new aftermarket ignition coils are junk so once you get your points fixed, you may need to use the original ignition coil or try a known good one.
The following user(s) Liked this Post: DVM, Jogar
22 Mar 2026 11:52 #10
