Houston we have a problem...
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Houston we have a problem... was created by AirborneSilva
So I was changing the stator side crank seal and while cleaning the area where the seal sits I noticed the part of the bearing that the rod goes through will spin, I'm pretty sure that aint right!
24 Aug 2025 12:24 #1
Replied by RT325 on topic Houston we have a problem...
That's a bugger. Gotta be fixed one day if not now. Could "try" laying it over totaly flat then use a loctite prep then try to work some loctite down on there. Otherwise it's replace the crank half or build up & machine which we did with a few yamaha v50 scooters back in the day. If it's "only just" turning with no up & down to feel it'll survive for a good while yet--but isn't good. Chances are if you dismantle you'll be able to measure the wear even if it's not visible except for being polished. Might be minimal wear in the bearing ring but you'd be very lucky if a new bearing fixes it. You might think yay it's tight pressing on then get to the last bit & --damn--loose. Don't get confused by c3-c4 or std clearance as that's in the ball race area not the fit on the shaft. Have a happy day, now I've ruined it sorry.
The following user(s) Liked this Post: MarkT, Snglsmkr, AirborneSilva, Ht1kid, Pete-RT1, Reed valve Richards
Last edit: 24 Aug 2025 15:38 by RT325.
24 Aug 2025 15:36 #2
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic Houston we have a problem...
It's all good Morely, as much as I wish it wasn't what it is I can't change it just have to deal with it. Maybe this will be the push I need to try my hand at splitting the cases. As far as up and down movement I didn't see any but then really wasn't looking for it either.
24 Aug 2025 15:47 #3
Replied by MarkT on topic Houston we have a problem...
Loctite now has a line of "wick in" products that could be tried.  I think they call them "after lock" or something like that.  I got a free sample at the hardware store and tried it out.  It actually worked really good!
I'd try to spray some brake clean a few times and blow it out with air to try to clean and dry it as good as possible, but it might just work if you lay the bike on its side as RT325 suggested.
(and add a few drops of oil to the bearing afterwards in case the brake clean washes it dry)
The following user(s) Liked this Post: Snglsmkr, AirborneSilva, Ht1kid
24 Aug 2025 18:10 #4
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thanks Mark, I guess I should have posted this before I put the new seal in and got it all back together. Oh well, I guess it's good practice.
25 Aug 2025 01:01 #5
Add it to the jobs to do one day list. Then I can't find my list when the time comes haha.
25 Aug 2025 15:43 #6
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Hi guys, so I got me some loctite that withstands heat up to 450*. I'm wondering if I apply a bit of heat with a heat gun around the area of the bearing and crank if it would help to pull the loctite in.
05 Sep 2025 11:41 #7
I'm no loctite expert so don't know but wouldn't want it to set before getting in & around if that can happen!!. Just dribble it around then move the shaftvevery which way untill it finds its way in-- & hopefully not in then out the back-- just stop when you think it's there. Then I guess there's - is the shaft central, but can't do a lot about that except hope. See what the experts on loctite say. I'm just kicking the subject off.
05 Sep 2025 15:44 #8
  • AirborneSilva
  • Platinum Member
  • Platinum Member
UPDATE:  So, after locktighting  (spelling), the bearing race to the crank I fired it up and realized the clutch side crank seal was bad.  Pulled the clutch side case off only to find needle bearings laying in the bottom of the case.  Ok, decided to just put all new bearings and seals in, along with a fresh bore (now it will be first over).  While the shop was putting in the new bearings they discovered that the reason why the bearing race was able to spin on the crank was it had the wrong bearing in it
.  The outer race fit correctly but the inner was not correct.  So, my reasonably priced bike is turning into not a very well priced bike.  Oh well, at least the motor for all intents and purposes will be new.  Side note, I need to man up and learn how to split cases and do all this work myself...
18 Nov 2025 07:33 #9
Replied by Schu on topic Houston we have a problem...
"Side note, I need to man up and learn how to split cases and do all this work myself..."
I know what you mean. I'm in the middle of that "Man Up" process right now. Splitting cases, replacing bearings, troubleshooting trans problem, along with a top end rebuild on one of my little JTs.
The following user(s) Liked this Post: MarkT, AirborneSilva, Ht1kid
18 Nov 2025 08:30 #10
