VForce Reed Block DT360
  • 45chop
  • 45chop's Avatar Topic Author
VForce Reed Block DT360 was created by 45chop
I saw this on the internet so thought I’d give it a try.
youtube.com/shorts/QCZhw2LQZTQ?si=dZgCLyGhPzimDN3T
17 Aug 2024 12:56 #1
Replied by RT325 on topic VForce Reed Block DT360
I'd be into that. Looks RT not DT360A as has 4 head studs I can see. 360A has a bigger reed block but they'll be available for those I'm sure. RT is same size as early YZ80 about "80 model or maybe "79 to just cross reference when looking.
The following user(s) Liked this Post: Snglsmkr, pabdt, Ht1kid
17 Aug 2024 15:32 #2
Replied by pabdt on topic VForce Reed Block DT360
dooby do. scooby's son?
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1973 Yamaha DT3 250
1974 Yamaha DT125A
17 Aug 2024 16:01 #3
  • 45chop
Replied by 45chop on topic VForce Reed Block DT360
You are correct it is an RT3, the Vforce4 block model number is V4R01H listed for a Husqvarna WR125 1996 - 2013
I keep mistakenly calling it a DT 360 because here in the UK people rarely know what an RT3 is.
17 Aug 2024 22:59 #4
Replied by MarkT on topic VForce Reed Block DT360
The 1973 360 model in Europe was actually named the "DT360" and from the brochure pictures I've seen had the same paint scheme as the US RT3.
From what a UK member said years ago, the Euro 1973 DT360 was never officially imported into the UK.
But yes, best to call even a bona fide European model an RT3 to avoid confusion with the far more common and nearly completely redesigned 1974 DT360A sold in the US.
18 Aug 2024 05:33 #5
I didn't see the 1973 DT360 European brochure in the Tech Library here...  but the model code "407" can be found in the model code lists.
18 Aug 2024 05:42 #6
  • 45chop
youtube.com/shorts/Lf18OS4SE_c?si=5AuL3K_t7YWQuYNd
Electrics to do and hopefully she runs good
20 Aug 2024 14:05 #7
Replied by pahiker on topic VForce Reed Block DT360
What carb are you running? Looks new.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
20 Aug 2024 16:08 #8
Power jet Nibbi Carb. Gotta get me one of those. Don't mention where it's made or you'll turn the post into like an oil thread--or maybe its only me thats had an ok run so far--not bought a Nibbi yet though. Looks the part i must say. Did that come with a range of jets.
So you have Vforce reeds fitted? or not yet.
The following user(s) Liked this Post: 45chop, pahiker
Last edit: 20 Aug 2024 21:14 by RT325.
20 Aug 2024 21:12 #9
  • 45chop
Yes, reeds fitted, Carb only came with two extra jets so I’ll probably need to get some more unless I get lucky. I’d post some more videos but seems to be YouTube problems at the moment.
20 Aug 2024 22:01 #10
