Gasket Installation Help Please
- Brzn
Gasket Installation Help Please was created by Brzn
Once I got my DT2 running after sitting for 27 years, I had a small leak of 2-Stroke oil from the base of the cylinder. Last winter I replaced the base and head gaskets installing the base gasket dry, nothing on it. Both mating surfaces were clean. Well this year it leaked, more than originally. Once I'd installed the gasket I torqued the head bolts to the recommended 30 foot pounds, then ran it through a couple heat cycles and retorqued the head, ran it through another couple heat cycles and checked the head bolts torque again and they were all fine.
I've purchased another set of base and head gaskets and plan to remove the cylinder again this winter. Should I apply something to the base gasket this time to keep it from leaking? Grease? High Tack Gasket Sealant? Something else?
22 Dec 2023 07:33
Replied by MarkT on topic Gasket Installation Help Please
I've been using a thin coat on both sides of the intake and base gaskets of the same special gray semi-hardening sealer used to assemble the center cases... Yamabond, Permatex MotoSeal, or Three Bond equivalent. (Pretty sure Three Bond makes Yamabond)
I pressure test after fresh assembly and without a little sealer on the base gasket and reed valve, I've almost always had a small air leak or two right after assembly... especially the reed valve intake. In my experience, air leaks never fix themselves, they get worse with time.
The following user(s) Liked this Post: Steve F, swm, Snglsmkr, Ht1kid, Pedalcrazy, msavitt, Tinkicker, Brzn, cranky_dave
22 Dec 2023 07:47
- 1971DT250
Replied by 1971DT250 on topic Gasket Installation Help Please
Ditto on what Mark said.
Are you using Yamaha OEM gaskets?
I've had trouble with aftermarket cylinder base gaskets on 2 of my RT3s installed by the previous owners. Replaced them with OEM.
The following user(s) Liked this Post: Ht1kid, Pedalcrazy, Brzn
- Brzn
Replied by Brzn on topic Gasket Installation Help Please
Hmm...
I bought the gasket off eBay and don't believe it's Yamaha branded.
23 Dec 2023 06:34
Replied by Ht1kid on topic Gasket Installation Help Please
Brzn you can go to a NAPA store and buy some good gasket material and make your own and use yamabond that’s what I do
23 Dec 2023 08:56
Replied by RT325 on topic Gasket Installation Help Please
Probably not what you really want to do--but on my YZ490 it used to suck in the base gasket along the side at the transfers.
So bought an old stock roll of gasket paper [cheap] slightly thicker than original & made a gasket a bit larger sticking out along the sides so when tightened down it left a very slight step & theoretically couldn't get sucked in.
Worked for me & wasn't that noticeable unless you got down close for a look.
The following user(s) Liked this Post: Ht1kid, msavitt, Sneezles61, Brzn
23 Dec 2023 15:29
- Brzn
Which Yamabond do I want for the cylinder base gasket to crankcase? On eBay I see there's a Yamabond 4, 5 and 6B. Then applied to both sides of the gasket?
I use the semi-hardening which I believe is #4
Permatex Motoseal is in stock at auto parts stores near me and is what I've used the last several years.
The following user(s) Liked this Post: Steve F, Brzn, cranky_dave
15 Feb 2024 04:56
- Paul@PJME
Replied by Paul@PJME on topic Gasket Installation Help Please
This is not a sales Ploy at all, but i use this on all paper type gaskets, I have found it very good. On some of the cheaper non coated paper gaskets, i give it a good soaking as it draws in in much more.
www.pjme.co.uk/acatalog/Loctite-Gasket-A...ay-1557.html#SID=655
I am sure you may find it Local to you
15 Feb 2024 12:12
- automan
Replied by automan on topic Gasket Installation Help Please
Indian Head
17 Feb 2024 00:13
