AT2MX- primary crankshaft gear
- PFC
AT2MX- primary crankshaft gear was created by PFC
I am looking for the metric thread size of the shaft thread - the one on my engine is buggered at the tip end and I can’t get the nut back on
hoping I can clean it up with the correct size die
thank you
thank you
12 Apr 2023 16:28
- Enduronut
- Founder Moderator
Replied by Enduronut on topic AT2MX- primary crankshaft gear
95% sure it's 12mm with 1.00 fine pitch
The following user(s) Liked this Post: asco, Ht1kid
12 Apr 2023 16:50
Replied by Ht1kid on topic AT2MX- primary crankshaft gear
You can use a thread file to clean up your threads see pic
12 Apr 2023 17:40
Replied by RT325 on topic AT2MX- primary crankshaft gear
Gotta be carefull with a die because if the first threads are compressed from someone belting the crank end, it's likely it'll start chewing the good threads after a false start [something like that]. Without knowing how bad it is i might try to taper off the damaged few turns to get to the good stuff. Then you might not need a die--might start & go on.
Or as HT1KID says with a thread file but still think i'd relieve the damaged thread then work backwards with the file starting from good & working your way out. Just my ideas.
12 Apr 2023 17:59
- asco
Replied by asco on topic AT2MX- primary crankshaft gear
My take is the primary shaft is hardened steel and the nut is not. Try a different nut first “before chasing thread of hardened steel. Start easy..”
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
12 Apr 2023 19:55
- PFC
Replied by PFC on topic AT2MX- primary crankshaft gear
thanks to all who replied!
i am going to run out and get a metric thread file - seems like the best way to go !
13 Apr 2023 08:12
- PFC
12mm 100 fine thread is the fit - thanks very much!
I was able to clean up the threads with a thread file along with gentle taps on the nut as it got hung up on the buggered threads;
slow and steady was the process - i can now get the nut on but will run out and get a new one for the reassembly.
Does anyone know the torque spec for this nut ?
04 May 2023 11:50
