clutch pushrod question
- richrd
clutch pushrod question was created by richrd
It is possible that the idiot who "went thru" the motor installed the wrong push rod, does anyone know the correct length?
I can dmake something to work but would rather make it right. What do you see?
Replied by MarkT on topic clutch pushrod question
I might be wrong but somehow I remember the pushrod coming out of the engine having a flat end, not rounded?
03 Feb 2023 11:03
- 1971DT250
Replied by 1971DT250 on topic clutch pushrod question
The pushrod is flatter on the ends with a slight taper. Overall length is 7 1/4 ". Sticks out 1 1/4".
03 Feb 2023 11:17
Replied by RT325 on topic clutch pushrod question
Is the 5/16 ball missing the other end under the mushroom where the pressure plate fits on. Doesn't explain the rounded end though--pirate pushrod out of something else maybe. #13 'ball'. I see the pushrod is drawn like it's in two pieces 'which it isn't'.
www.partzilla.com/catalog/yamaha/motorcycle/1971/dt1e/clutch
03 Feb 2023 14:35
- Dennis D
Replied by Dennis D on topic clutch pushrod question
Very possible it is the wrong push rod. I bought one off of the bay that was suppose to be the correct part number and it was about that much too short. The vendor took it back though. I may have a picture of the two somewhere that I could send directly to you. Do you not have your old one to compare?
04 Feb 2023 13:39
- richrd
Replied by richrd on topic clutch pushrod question
it was definitely the wrong pr. 3/4 inch to short. that's the way this bike was assembled. if I ever get the urge to write a horror novel Ill tell you all about it.
07 Feb 2023 06:46
