'73 Air Box Foam Padding
'73 Air Box Foam Padding was created by MarkT
Would be helpful to mention the model... you know what you're working on, we don't.
09 Jan 2023 07:06
Replied by Gr8uncleal on topic '73 Air Box Foam Padding
"Sherlock" Al reckons it's a DT3!
09 Jan 2023 07:12
- Dennis D
Replied by Dennis D on topic '73 Air Box Foam Padding
I can send you some pics. Photos not working on here.
09 Jan 2023 12:57
- adguy2112
Replied by adguy2112 on topic '73 Air Box Foam Padding
I cut up a piece from a black mouse pad and used upholstery spray glue. It worked great and also worked for the bottom of the battery box. I know its not original but the idea is.
09 Jan 2023 17:06
- Dennis D
Need an address to send them to. Or I can send them to your cell.
- Dennis D
If it's there, I can't find it.
10 Jan 2023 13:48
- AirborneSilva
Replied by AirborneSilva on topic '73 Air Box Foam Padding
Hobby Lobby sells foam pads with glued backs of various sizes.
11 Jan 2023 04:07
- Evman100
Replied by Evman100 on topic '73 Air Box Foam Padding
Can someone provide the dimensions of the foam padding?
24 Feb 2023 16:41
- Brzn
Replied by Brzn on topic '73 Air Box Foam Padding
‘72 DT2, I just happened to receive a shipment of some fruit from Harry and David’s while I had my battery box out. The foam that was in the packaging protecting the fruit was the exact same foam; same thickness and same cell structure as what I was pulling off the battery box. Only difference was its color, a pale green instead of the beige color of the original foam.
The foam I used was 1/2” thick. I’ve no other measurements, but you can see in the below pics where the original foam was.
