Same Part Number but Different Part?
  • RT325
  • RT325's Avatar Topic Author
  • Platinum Member
  • Platinum Member
That's very interesting is 'that' See what others say & thanks for posting.
09 Dec 2022 14:04 #1
Replied by SKYDANCER46 on topic Same Part Number but Different Part?
Which ever one you buy or use, be sure to line the 2 little dots up on the back side when putting this assembly back together.
09 Dec 2022 17:21 #2
Replied by MarkT on topic Same Part Number but Different Part?
Yamaha was very diligent at marking updated parts with a unique suffix such as "-10".  It would be unusual for them to make such a dramatic change to a part and not identify it.
Ebay sellers are also very good at posting parts next to Yamaha packaging...  packaging they often don't send with the part...  so there is a chance that several sellers are listing the part with the extra teeth incorrectly?   (Note the ebay auction you linked to showed the two different parts and one package)
There is a similar part with a 363- prefix that was used on the SC500 that does have the extra teeth... and seems to have been superseded.  It might be possible some sellers are misidentifying the part and the one with more ratchet teeth is actually a 363-15671?
i.ebayimg.com/images/g/IoMAAOSwETJaDHXS/s-l500.jpg
Ebay 363-15671 SC500
The key is checking to see if the ratchet teeth engage properly with the mating gear.
The following user(s) Liked this Post: Ht1kid, msavitt
Last edit: 10 Dec 2022 07:16 by MarkT. Reason: First paragraph got lost
10 Dec 2022 07:13 #3
The dot on the kick start shaft is extremely hard to see or may be gone. As for the line up, i think it changes the spring tension after its all assembled and back in place if not correctly lined up.
Last edit: 10 Dec 2022 08:01 by SKYDANCER46.
10 Dec 2022 08:00 #4
