RT3 Head Studs
  • Eveready
  • Eveready's Avatar Topic Author
RT3 Head Studs was created by Eveready
I bought a 73 RT360 that needed new points.  I removed the head to time it. One of the small head studs pulled out it was J-B welded in and it had 2 head gaskets on it. My question is will the head gasket seal with only 3 off the 4 small head studs.
04 Oct 2022 10:43 #1
Replied by msavitt on topic RT3 Head Studs
I do not think so, but others will know better.
Personally, I would pull the cylinder, seal off the crankcase with duct tape and install a heli-coil to repair the threads in case.
04 Oct 2022 10:49 #2
  • Eveready
Replied by Eveready on topic RT3 Head Studs
There not in the case there in the jug and it is to close to the steel sleeve to heli-coil the dril bit would just walk off in to the alumi.
04 Oct 2022 11:16 #3
Replied by 1971DT250 on topic RT3 Head Studs
I recommend not using that cylinder. Might get an air leak and cause a high rpm lean condition runaway that could result in a seizure. Previous owner likely had trouble which is why he installed 2 head gaskets.
eBay sometimes has cylinders. I don't recommend going past the second oversize on the 360 as the cylinder wall will be too thin. The cylinder wall on a new 360 is 4mm thick. The 250 is 5mm. And the 250 doesn't generate as much heat as the 360.
Send me a PM if you're interested in a new old stock cylinder with standard, first and second oversize pistons and rings.
Last edit: 04 Oct 2022 16:12 by 1971DT250. Reason: Added info.
04 Oct 2022 13:49 #4
Replied by Ht1kid on topic RT3 Head Studs
Maybe a time-sert would work
04 Oct 2022 15:05 #5
Replied by MarkT on topic RT3 Head Studs
Loctite makes "form a thread" epoxy.  At least they did.  haven't looked for it in a while.
I've found it works great if you follow instructions.
04 Oct 2022 15:13 #6
Also, 1/4" is just slightly bigger than 6mm. Sometimes you can tap 1/4" thread in a stripped 6mm hole and use a 1/4" stud.
The following user(s) Liked this Post: Ht1kid, Pedalcrazy
Last edit: 04 Oct 2022 15:23 by MarkT.
04 Oct 2022 15:20 #7
  • Eveready
I'll try a 1/4 tap tomorrow. If that don't work I'll consider another jug.
04 Oct 2022 16:21 #8
Replied by RT325 on topic RT3 Head Studs
Don't panic. What i'd do is try a long hightensile 8mm bolt & you might find unused thread past where the stud finished. Screw it to the bottom then cut the head off for the nut. I've made up 9mm bolts as have a 9 tap & works too. Anyway--i think it'll be ok with three dtuds as you have the 4 big ones holding it all down. Not sure about two head gaskets--second one must be unsupported around the edge & you'd have to line it up square over the top & not bump it fitting the head down. Think i'd just anneal one gasket--red then quench. Grease it & tighten her down. 250 only has the big 4 & is ok. Maybe YZ250A has the extra studs but don't go there. If the alloy is pulled, in my opinion nothing magic will fix it except hellicoiling or similar.
04 Oct 2022 17:06 #9
Who said 6mm they're 8mm the 4 studs.
04 Oct 2022 17:07 #10
