How to safely remove spring clamp?
  • AirborneSilva
  • Platinum Member
  • Platinum Member
How to safely remove spring clamp? was created by AirborneSilva
I need to change the small hose from my oil pump to cylinder, how do you safely remove the spring clamp.  Also, how does it go back on?  Thanks!
27 Jul 2022 12:40 #1
Replied by Gr8uncleal on topic How to safely remove spring clamp?
In the past I have managed to slide them down the hose.
Some folks have recommended warming the hose first, just to make it easier.
Goes back on the same way.
Note that the clamps that Yamaha supply now have a silver finish, not black.
27 Jul 2022 12:49 #2
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic How to safely remove spring clamp?
Thanks Alan, I did tug on it a bit but felt uneasy to give it a good pull.  I'll heat it up and try again when my new line comes in.
27 Jul 2022 12:51 #3
I think that I used my nails
, or maybe a small screwdriver.
27 Jul 2022 12:54 #4
  • AirborneSilva
  • Platinum Member
  • Platinum Member
I thought about using some needle nose pliers to pull it off, don't want to damage the pump.
27 Jul 2022 12:56 #5
Replied by 1971DT250 on topic How to safely remove spring clamp?
Get your fingernail or a small thin screwdriver under it and try to unwind it as you push it off.
Last edit: 27 Jul 2022 23:41 by 1971DT250.
27 Jul 2022 15:10 #6
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thanks, I'll give that a try.
27 Jul 2022 17:05 #7
Replied by Pedalcrazy on topic How to safely remove spring clamp?
Yes don't pull anything. If you grab it and pull you'll be making it grip tighter. I use a small screw driver behind it and push it off.
27 Jul 2022 17:47 #8
  • AirborneSilva
  • Platinum Member
  • Platinum Member
And this is why I ask these questions, I would have been pulling on it and saying lot's of swear words when I either broke it or just couldn't get it off.
28 Jul 2022 02:33 #9
Replied by Schu on topic How to safely remove spring clamp?
You’ll still need the swear words.
28 Jul 2022 09:19 #10
