Steering damper removal
- hcdiiiga
Steering damper removal was created by hcdiiiga
1973 DT3
I'm missing something on removing the steering damper? I removed the bolt ( that seems to secure it to the steering head, it looks like just a short splined shaft holding it in the diagram. I've wiggled and tapped on the damper about as a hard as I am comfortable doing. Someone had removed or attempted to remove the bolt before, I was lucky to get out with an impact driver,
24 Apr 2022 09:01
- 1971DT250
Replied by 1971DT250 on topic Steering damper removal
It can be buggered up inside there. Doesn't take much to hang it up. Careful surgery may be required. I've removed the entire front end to get one out. I was also dealing with other issues so the front end needed to come off anyway.
24 Apr 2022 09:18
Replied by MarkT on topic Steering damper removal
What did the screw you removed look like? It should have had a few threads near the head and then a length of smaller diameter section with no threads. I've seen the screw break somehow... the short threaded part comes out and the "pin" stays in there.
The following user(s) Liked this Post: 1971DT250, Pedalcrazy
24 Apr 2022 09:40
- Sneezles61
Replied by Sneezles61 on topic Steering damper removal
So with "Its installed from the factory, so I has to be there" take on the damper... Any of you feel its really needed?
Sneezles61
Sneezles61
24 Apr 2022 10:02
"So with "Its installed from the factory, so I has to be there" take on the damper... Any of you feel its really needed?"
I've had conversations with an engineer who worked at a motorcycle manufacturer for many years... he said it's a "band aid" if used for correcting steering instability/vibration... just shifts/masks the design or loading issue.
Might have some use off road to absorb shock. I've never noticed a difference with or without on one of these old bikes.
24 Apr 2022 10:20
- hcdiiiga
Replied by hcdiiiga on topic Steering damper removal
That is exactly what happened. After reflection I recalled that I had ordered that bolt off of Ebay, I finally located it in the vast collection of ebay parts I have to put this bike back together, it was clear what happened after seeing the new bolt. I bet the remaing part will spin if I try to drill it.
- hcdiiiga
I've never put an aftermarket damper on a bike, my KTM 790 has one from the factory, I don't think it does much, I doubt the one on the yamaha does much of anything at all, but yeah, it has one so I would to keep it , which is not a problem since I can't get it off.
24 Apr 2022 11:17
Replied by RT325 on topic Steering damper removal
Had one break off the extension bit in one of my bikes many years ago but was lucky enough to have it come out when setting it up verticaly & giving it a good talking to. On that one i tapped a thread in the damper [hard matterial] & must've drilled the few turns of thread out of the lower tripple. Actualy i think i just tapped it right through just continuing from the short tripple yoke thread so allen screw would need to find the thread start in the damper. Whatever, it worked & plan was to take 'Any' sloppy movement out of it--which it did. Experimented with oil viscosity a litte but made it too heavy for the road. Might've been good in MX though.
24 Apr 2022 17:43
- hcdiiiga
I managed to get the offending bolt part out using a combination RT325's experiences. I drilled down and when the drill started getting wobbly I figured I was approaching the hole in the spline, The steering stem was already out so it was no problem to turn it to the vertical and attempt to coax it out. It took about 15 minutes of persuasion for it to get where I could grasp it. Didn't damage the threads too much, they cleaned up with a tap enough for the new bolt to go in..
25 Apr 2022 16:35
