Tach Driven Gear O-Rings Leaking Help
- Brzn
Tach Driven Gear O-Rings Leaking Help was created by Brzn
I'd posted this question in the thread I have going regarding my restoration, but haven't received an answer. I'll be a bit more direct and make a new post about it here.
It looks like there are two O-rings at the tach housing assembly #5. Does anyone have any info on replacing these? I've got an oil leak here and would like to replace them.
I've removed the tach cable and the bolt #12 holding the stopper #11 and have gotten the housing assembly to lift slightly, but it's tight at this point.
I don't want to force it if it's being held by the driven gear #6, or is it just the O-ring #7 holding tight? Is this O-ring in a grove in the housing assembly, or is it between the housing assembly and the driven gear? I really don't want anything to drop into the case for fear I'll have to split it to simply retrieve something I shouldn't have messed with.
Thanks in advance
Thanks in advance
Replied by RT325 on topic Tach Driven Gear O-Rings Leaking Help
Just google imaging it looks like the outer Oring is in a groove on the item that comes out so i guess its just hanging on & wants a twist & a lever upwards. The split collar for the internal small Oring could be fun to get out. Might have to get up from the bottom when the assembly is out & push on the small Oring which will probably destroy it to push the collar with flat washer out. Better wait until someone that's actually performed the operation comes along. I'm only looking at pics. Small Oring isn't the best plan for something spinning but i guess it does the trick or it'd be a proper seal.
16 Apr 2022 15:12
- Grussell
Replied by Grussell on topic Tach Driven Gear O-Rings Leaking Help
The housing is a tight fit. You can remove it with no issues. If you need the o-rings www.rockymountainatvmc.com has both in stock.
1978 DT400
1975 DT250
1976 YZ125X - my post vintage race bike
2022 KTM 300XCW - my race bike
1975 DT250
17 Apr 2022 09:15
- Brzn
Replied by Brzn on topic Tach Driven Gear O-Rings Leaking Help
Got it!
The following user(s) Liked this Post: MarkT, RT325, Grussell, Sneezles61
17 Apr 2022 13:54
