Love my RT2
- Sneezles61
Love my RT2 was created by Sneezles61
could you post a closer look at yer decompression lever? Mine sits on top.. I'd like to see how yers is configured/bolted underneath..
Sneezles61
Sneezles61
10 Dec 2021 06:23
- Sneezles61
Replied by Sneezles61 on topic Love my RT2
Sure looks like when you pull towards you.. then the cable is being pulled also.. I'll forget some times and when I realize its not running right.. The light bulb goes off... close the valve! Wouldn't it be nice if it did that all by its self?
Sneezles61
Sneezles61
10 Dec 2021 07:41
Replied by MarkT on topic Love my RT2
If you search there's a whole bunch of debates on where lever "should" be mounted... kind of like an oil thread.
The experts seem to agree that mounting on top is "correct"... promo photos can be found showing both ways.
10 Dec 2021 07:58
Replied by Gr8uncleal on topic Love my RT2
"The light bulb goes off... close the valve! Wouldn't it be nice if it did that all by its self?"
Yamaha thought the same, and fitted the 1974 (DT360A) on bikes with the valve linked to the kick starter.
10 Dec 2021 08:01
It actually makes sense to mount it on the right if underneath.
Like I said, there's been a lot of debate on that feature and what's "correct"... Yamaha diagrams and photos show multiple variations.
10 Dec 2021 08:45
- Sneezles61
Sooo.. it depends what mood yer in? That depicts the local?
Perhaps when I do my resto, I'll move it underneath...
Mauser, yers springs back? Don't need to fiddle with it after it starts? I won't say there is a big difference running with the valve open.. but I can tell when you are loping around and need to get after it..
Sneezles61
Sneezles61
10 Dec 2021 09:00
- Swoop56
Replied by Swoop56 on topic Love my RT2
Mauser . You have confused the front brake light switch , with the decompression lever assy .
In your defence , it does look similar in the diagram , but they were all mounted on the left .
10 Dec 2021 12:42
- Pedalcrazy
Replied by Pedalcrazy on topic Love my RT2
Since the decomp lever isn't spring loaded you'll want to close it after the bike starts. If you haven't been doing that the valve may not completely close now with carbon built up. The little spring on the valve itself isn't strong enough to spring back the lever. You'll be losing compression and power. My RT3 and RT1 both run differently at startup until I close the valve via the lever. Using new parts and cables too.
10 Dec 2021 15:40
- Sneezles61
Never gave much thought to the effects of it getting gumpuckied up from exhaust.. Makes sense..
Sneezles61
Sneezles61
10 Dec 2021 19:44
- Pedalcrazy
MAUSER...glad it works for you. Pretty small spring on the decompression unit. Maybe I'm running my lever on the handlebars snugged down too much. Anyway, just my experience.
11 Dec 2021 06:08
