Clarke #SFLA Fuel Tank?
- RT3Sam
Clarke #SFLA Fuel Tank? was created by RT3Sam
Has anyone installed a Clarke #SFLA on their DT or RT? My original fuel tank is in great shape with original paint. I'm afraid of dropping this bike and damaging the fuel tank, so I'm thinking of installing the Clarke. Plus it gets me an extra gallon of gas. So I'm looking for feedback from anyone who has installed one and advice on how to install it.
Sam
Sam
02 Aug 2021 10:22
- KennyV
Replied by KennyV on topic Clarke #SFLA Fuel Tank?
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
21 CRF300l Rally
The following user(s) Liked this Post: MarkT, RT3Sam
02 Aug 2021 11:46
- RT3Sam
Replied by RT3Sam on topic Clarke #SFLA Fuel Tank?
Thanks KennyV!! I was having trouble pulling up the pictures and was finally able to today. Do you have any sketches or drawing with dimensions of the brackets you made? Seeing the picture of your bike with the tank installed sealed the deal for me!! That looks sweet!!!
Sam
03 Aug 2021 17:06
- KennyV
Hi Sam, thanks! Sorry I don't have any sketches of the mounting hardware. Later today I will take better pictures with dimensions of what I made.
71 Z50 Minitrail
21 CRF300l Rally
21 CRF300l Rally
The following user(s) Liked this Post: RT3Sam
04 Aug 2021 06:02
Replied by MarkT on topic Clarke #SFLA Fuel Tank?
I'm thinking a product called "Kenny's SFLA tank brackets" would sell at least a few sets.
The following user(s) Liked this Post: KennyV, RT3Sam, Pete-RT1
04 Aug 2021 06:17
- DEET
- Moderator
Replied by DEET on topic Clarke #SFLA Fuel Tank?
Here is my SFLA tank.
I made a clamping mount with flat bar and a couple of bolts.
I sandwiched the frame tube between two pieces of aluminum bar and ran a long rod through the front holes.
I used short pieces of PEX tube to center the tank between the brackets. Tube goes over the long rod between the tank and the bracket.
Not nearly as nice as Kenny's.... more of a "stone knife and bearskin" primitive version.
The following user(s) Liked this Post: MarkT, Steve F, JayB, KennyV, RT3Sam, Pete-RT1
- KennyV
I hope this is helpful.The "hockey pucks" 11mm x 39.7mm. I put a good size 45 degree chamfer on the one side of each and had friend tig weld them to the 1/8 aluminum. I set them up in my lathe and turned the excess weld off. I placed them each in the "ears" on the frame and transfer punched, drilled and taped m6. Where the ears are welded to the frame there's two thicknesses of metal so plenty of meat there to thread.
From the center of the 6mm hole through the center of the puck to cetera of the crimp nut 70mm. No need for the third mounting spot. That was for mounting on my 400C.
the piece on the far left comes with the tank if remember correctly. The one to right is one I made with stainless and a little longer so the rubber band didn't stretch as far. And there's the crimp nuts I used, they work great for things like this you don't have to worry with a nut on the back side. And the foam rubber that goes on the frame for the tank to rest on.
The piece for the rubber band to hook on screws on here. I have the piece I made for my 400 on so it sit on my storage stand.
71 Z50 Minitrail
21 CRF300l Rally
21 CRF300l Rally
- KennyV
The spacers, 10mm diameter, 35mm overall lenght, 3mm x 14mm shoulder. I did have bend / tweek the 1/8 aluminum for everything align on my RT.
I do recommend you buy an aluminum cap. My plastic cap cracked while I was on a 5 day adventure ride. I have one from Tusk. Hopefully their still available.
And my storage stand I made mainly for when I was using the Clarke tank. A place to put my almost perfect original 400C tank.
71 Z50 Minitrail
21 CRF300l Rally
21 CRF300l Rally
The following user(s) Liked this Post: MarkT, Steve F, Schu, Pete-RT1
04 Aug 2021 12:17
- RT3Sam
Thanks KennyV and DEET!! That gives me some good ideas on how to mount my tank. KeenyV thanks for showing me your storage mount, I think I'll make one of those for my RT3 tank. Its not perfect, but its all original. One last question, DEET, where did you get the black and white stripes for your tank? They look good on there.
Sam
Sam
05 Aug 2021 05:56
- DEET
- Moderator
The white tank stripe is a decal.
The yellow tank stripe I painted.
05 Aug 2021 06:38
