AT3 removing the rotor - changing the brishes
- Chajoma
AT3 removing the rotor - changing the brishes was created by Chajoma
What suggestions on how to remove the rotor from my AT3? There seems to be an M10 thread inside the rotor but I cannot get an M10 bolt o thread into it - is it a fine thread? Do I need a special puller?
And any tips on replacing the brushes? It's not charging and they look pretty bad to me but I cannot see how to get them out.
Any advice gratefully received
- Chajoma
Replied by Chajoma on topic AT3 removing the rotor - changing the brishes
Brushes not brishes - I don't seem to be able to edit the title
08 Jul 2021 09:39
Replied by Gr8uncleal on topic AT3 removing the rotor - changing the brishes
You'll be calling them brishes after
Good to see you back!
08 Jul 2021 09:49
- tennbamaman
Replied by tennbamaman on topic AT3 removing the rotor - changing the brishes
Smarter folks than me will answer but if you search "
1971 ATC1 Armature puller bolt was created by tennbamaman
you will see one of many topics on the bolt puller. The full threaded 3 inch bolt listed in that series worked great for me with an electric impact driver. Also, you will find that you have to take brushes out before you can reinstall the Stator anyway. On the front of the stator there are 4 coiled springs that hold each brush in. Take a pick and pull the spring back and pull the brush out while the spring is pulled back.
The following user(s) Liked this Post: Chajoma
08 Jul 2021 12:10
- tennbamaman
oh yea, just curious why do you want to remove the armature? There is a woodruff key on that shaft that lines the armature up.
08 Jul 2021 12:47
- Chajoma
I'm replacing the crank seal.
08 Jul 2021 12:52
Replied by RT325 on topic AT3 removing the rotor - changing the brishes
Here's the correct puller & pushes from the bottom of the hole in the crank.
08 Jul 2021 16:02
- Chajoma
Hmm. The one I ordered from Yambits doesn't look like that. I'll take a look when it gets here.
Is that one all one piece? It looks like it and that would make sense to me. Hmm. The one I ordered from Yambits doesn't look like that. I'll take a look when it gets here.
- shyted
Replied by shyted on topic AT3 removing the rotor - changing the brishes
I don't want to sound like i'm trying to be smart but have you downloaded a free workshop manual from the task bar? Yamaha manuals tell you what tools you need. I would imagine that that process is visited in there too or you will see " Consult your authorised dealer" at least .
09 Jul 2021 01:27
- Swoop56
Replied by Swoop56 on topic AT3 removing the rotor - changing the brishes
The Yambits tool fits all the enduros except the electric start 125's .
It does fit the magneto AT3 F , but as yours is an AT3 E , you need the long tapered bolt .
09 Jul 2021 04:08
