Dt2 running with trail tech temperature gauge
  • wbrewstersr@gmail.com
  • wbrewstersr@gmail.com's Avatar Topic Author
Dt2 running with trail tech temperature gauge was created by wbrewstersr@gmail.com
Just came back from a 16 mile round trip trying to break my bike in slowly kept in just under 50 mph with about 4.75 on the tachometer temperature got as high as 374 deg.f
had about 5 miles straight without a stop sign each way
when coming up to stop sign it would drop to around 330 deg f
then climb back up slowly
Does this seem ok I have read that I need to  stay below 400 deg f by the way the outside temperature is around 92 deg f
thanks
26 Jun 2021 20:09 #1
Replied by wbrewstersr@gmail.com on topic Dt2 running with trail tech temperature gauge
Seems to be leaking a little around the bottom of the cylinder I torque the head bolts to 35 lbs
Does anyone know the torque specifications I replaced top and bottom gasket did not use any gasket maker or silicone
26 Jun 2021 20:21 #2
If it's leaking around the bottom of the cylinder that'll throw the temps off for sure. Cross pattern, 25-30ft lbs for the bolts. Since it's leaking I'd get a new gasket and make sure both surfaces are super clean before reinstalling.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
26 Jun 2021 21:42 #3
1972 Yamaha CT2 175
1997 BMW R1100R
2013 Yamaha XT250
26 Jun 2021 21:45 #4
I tighten the head bolts to 39 lbs seems to have worked let her run for 30 minutes not a drop of oil tomorrow I will take her for a spin and monitor everything
26 Jun 2021 22:34 #5
Replied by DT400FRANK on topic Dt2 running with trail tech temperature gauge
Try not to hold the tpms in one spot for long. Two strokes like varied rpms especially during break in.
26 Jun 2021 22:41 #6
Thanks Frank
26 Jun 2021 22:46 #7
If it idles fine at lower temps but not at high temps, that could be a sign that the base gasket is still leaking, it can't hurt to have that in the mental files as you progress. Great looking bike and hope you get some fun miles on it!
1972 Yamaha CT2 175
1997 BMW R1100R
2013 Yamaha XT250
The following user(s) Liked this Post: wbrewstersr@gmail.com
27 Jun 2021 09:38 #8
