Wiring Ampage
  • EM ONE
  • EM ONE's Avatar Topic Author
Wiring Ampage was created by EM ONE
I need to rewire My RT3,its running the old original 6 volt electrics,do any of you know what ampage wiring i will need.It looks as if the options are 8/17/27/35 amps
Cheers in advance
16 May 2021 15:25 #1
Replied by JayB on topic Wiring Ampage
I would look at the recommended fuse that is in line with the battery, and size it to at least meet that.  A lot of considerations go in to wire sizing, but that would probably be the quickest way to make a good choice.  Maybe upgrade one size if the wire is still flexible enough for the wiring harness.  The fuse or circuit breaker is there to protect the wiring.  If a load like a light bulb were to short out, the fuse would open instead of the wire melting or starting a fire.
You have to use stranded wire, NOT solid!
Replacement used and NOS harnesses are available, and someone here on the site makes nice correct replacements.
Last edit: 17 May 2021 18:41 by JayB. Reason: corrected spelling
17 May 2021 18:40 #2
Replied by Mothersbaugh on topic Wiring Ampage
Member DEET here does wiring harnesses.
17 May 2021 19:36 #3
Replied by MarkT on topic Wiring Ampage
I've never seen wire sold by "ampage"...  usually it's sold by wire gauge or by mm2 so that's kind of interesting.
Not sure what the highest current wire on the bike is...  but 6 volts x 8 amps = 48 watts which sounds barely adequate so I'd probably go for the 17 amp minimum
The following user(s) Liked this Post: Bigdog302, JayB
17 May 2021 20:30 #4
Replied by Pedalcrazy on topic Wiring Ampage
I'd contact member DEET as he makes complete harnesses using the original wire sizes, colors and connectors. I don't know why you'd buy bulk wire and try and rewire a bike.
18 May 2021 18:15 #5
  • EM ONE
Replied by EM ONE on topic Wiring Ampage
Im from the UK and Ive looked at wiring harnesses on ebay, theres a new one on at present in the states for 220 pounnds then theres shipping on top of that 50 plus any import taxes,nearly half what i paid for the bike in the first place.So i thought it would be a good idea to make my own.A supplier over here,sells the wires according to ampage,
22 May 2021 10:19 #6
Replied by DEET on topic Wiring Ampage
My harness is $138 gbp and $13 gbp shipping.
22 May 2021 11:46 #7
Replied by Gr8uncleal on topic Wiring Ampage
Sticking my nose in here, but a couple of pertinent points:-
1) DEET's work comes highly commended.
2) If the value on the CN22 customs form is shown as less than £135, then my understanding is that UK VAT (20%) is not charged (the taxation rules changed on 01/01/2021).
22 May 2021 11:58 #8
Replied by Pete-RT1 on topic Wiring Ampage
Alan, I think the VAT at 20% is still applicable. I think the change was where the VAT was collected, the onus is on the seller to collect it as I understand it. I think the £135 figure is the threshold for import duty.
Yamaha CT3 (in bits)
Last edit: 22 May 2021 15:57 by Pete-RT1.
22 May 2021 15:55 #9
And the seller is the one who decides what to put on the customs form....
The following user(s) Liked this Post: MarkT, swm, Gr8uncleal, Pete-RT1, msavitt, Jack
22 May 2021 17:56 #10
