1973 AT3
  • Rookie1234
  • Rookie1234's Avatar Topic Author
1973 AT3 was created by Rookie1234
Hi! I'm new to mechanics and need a little help. My 1973 at3 dosnt have spark and I've lost my way, it dosnt charge and the starter dynamo dosnt work, I'm not sure what I'm doing but don't want to take it somewhere. HELP!
09 May 2021 14:18 #1
Replied by RT325 on topic 1973 AT3
Firstly Welcome.
How do you know it doesn't charge as won't until running. Ok back to the beginning. Needs 12 volts to spark. So if you flick the points with a screwdriver you should get spark from screwdriver & points plus at the spark plug. Then when running it should poke about 14.5 volts back to the battery plus the starter should operate. That depends on condition of the carbon brushes but if under spring tension they should work even if worn down. Should still spark & run via kickstart even if brushes are stuffed. Let's know a bit more please. Jump it to your car battery. My AT1 is magneto ignition, trouble free & simple but did have an electric model years ago. Thanks & Cheers from NZ downunder.
Last edit: 09 May 2021 15:33 by RT325.
09 May 2021 15:31 #2
  • Rookie1234
Replied by Rookie1234 on topic 1973 AT3
Thankyou for the tips! The reason I think it isn't charging is I did have it running a year ago but it would always die after about 6 hours of running time. I wish it was magneto setup, lol.
10 May 2021 11:29 #3
  • Rookie1234
Just took the battery off the charger and it read 12.88 volts. Tried to pop the points and no spark. Maybe the wiring is messed up?
10 May 2021 12:44 #4
Replied by Pedalcrazy on topic 1973 AT3
Check that the main fuse hasn't blown.
10 May 2021 14:53 #5
  • Rookie1234
Finally got it running again, I took a little sand paper to the points and that fixed it, rode it for a good 4 hours today. Still not charging the battery though....
10 May 2021 16:20 #6
Replied by Gr8uncleal on topic 1973 AT3
Check on the condition of the four brushes in the starter/generator.
11 May 2021 00:10 #7
