Oil Tank Cap
- phrog44
Oil Tank Cap was created by phrog44
I am slowly resurrecting my 1972 DT2 250. The oil tank and oil tank cap are original but the threads on the cap don't match the thread on top of the oil tank. I know there is a missing gasket but, I can't find anything to indicate that an adaptor is used to seal the cap and adapt the different threads. What am I missing?
- 1971DT250
Replied by 1971DT250 on topic Oil Tank Cap
These caps shrink over the years. Same for Honda and Toyota cars. Need to buy a new one. Several sources including Yamaha dealers and eBay.
The following user(s) Liked this Post: Enduronut, Steve F
27 Mar 2021 11:35
- run103
Replied by run103 on topic Oil Tank Cap
I use fishing boat plugs They seal better and they are easier to get out The rubber ones that are brass and the tip 90 degrees to lock.
Doug
Doug
The following user(s) Liked this Post: 1971DT250, Yamadude
27 Mar 2021 11:56
- phrog44
Replied by phrog44 on topic Oil Tank Cap
The cap is hard plastic. I don't think it has shrunk much, but it probably didn't seal on its own. It seems there is a rubber part missing.
The fishing boat plug may work if I could find one the right size.
- 1971DT250
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=291300515226&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- run103
The boat plug is the best but I wiil admit it aint stock. BUT it doesn leak and if it does you acan tighten it up to make it bigger. Whatever works and who sees it anyways. But they do see leaking oil;
Doug
Doug
The following user(s) Liked this Post: Yamadude
27 Mar 2021 16:08
- MACE6772
Replied by MACE6772 on topic Oil Tank Cap
I suggest one of the chinese machined aluminum caps. Yeah you read that right. I now have 2. Look stock, never shrink or break, all black. About $ 11.00 each plus shipping. oh yeah, uses stock gasket.
- Yamadude
Replied by Yamadude on topic Oil Tank Cap
I have the same issue with my DT3 cap.
I like the alternatives mentioned above (maybe less pricey than the $24 OEM?), but how about a link you guys ?
You can just call me Dude.
Syracuse, New York
Syracuse, New York
27 Mar 2021 17:49
- phrog44
I measure a 1-1/8" opening. I can find 1" and 1-1/4" boat plugs. I have not used these before. Do I go oversize or undersize, or keep looking?
28 Mar 2021 07:29
- Yamadude
I gave some thought to all three options presented for fixing the Incredible Shrinking Tank Cap issue, which I have as well as phrog44.
However, all three solutions involve 1.Spending more money, and 2.Letting go of my original tank cap. As you know, a bike is only original once.
So, I decided to unshrink the original cap. I carefully heated it from the inside with a torch so as to not mess up the threads, and then pushed a socket into it which was just a wee bit larger than the cap interior. This forced the threads out.
Then I cut a gasket out of some thick gasket sheet stock.
So, now I have my original cap fitting snug in its threads, and I didn't spend a penny.
Dude
Dude
Syracuse, New York
Syracuse, New York
The following user(s) Liked this Post: 1971DT250, Steve F, Bigdog302, yamahahaha, asco, Gr8uncleal, Schu, Jack, phrog44
