Knocking in 1973 RT360
Replied by Wrench66 on topic Knocking in 1973 RT360
Yup, that lower rod bearing is a goner.
Time for a lesson in splitting cases ;)
-- Ray
Nothing makes me smile like the smell of Blendzall green label ;)
The following user(s) Liked this Post: 2noSmoke, 45chop
14 Aug 2024 16:19 #11
Replied by AirborneSilva on topic Knocking in 1973 RT360
I see the wrist pin moving, I'd say your pin bearings need to be replaced or perhaps someone put the wrong wrist pin in?  Not an expert here, just guessing
17 Aug 2024 09:12 #12
Replied by Schu on topic Knocking in 1973 RT360
Uh oh….. Every one of my bikes sound like that video
The following user(s) Liked this Post: MarkT, pabdt
Last edit: 17 Aug 2024 10:30 by Schu.
17 Aug 2024 10:29 #13
Replied by MarkT on topic Knocking in 1973 RT360
IMHO, video in post #9 appears meaningless to me. Seems to be bone dry with no oil. New parts almost certainly will click like that if dry... especially the piston movement.
(clean all the oil from a new crankshaft ball bearing and shake it... it will rattle... doesn't mean the brand new bearing is worn out!)
Silly idea... why not actually measure the big end bearing wear as described in the service manual?
The following user(s) Liked this Post: Snglsmkr, pabdt
17 Aug 2024 11:53 #14
Replied by 2noSmoke on topic Knocking in 1973 RT360
If you hold the piston at mid stroke, then rotate the flywheel back and forth you will quickly see/ feel any play in either the big or little end. Now that the cylinder is off, you might want to put two equal blocks across the crankcase under the piston and let it find its natural alignment with the con rod. Hold the piston stationary and rock the flywheel. Any play at all and the bearing needs to be replaced IMEDIATELY. This is especially true of the big end, because it's replacement is often avoided if possible, but failure is catostrophic.
The following user(s) Liked this Post: Snglsmkr, 45chop
17 Aug 2024 17:04 #15
