Front suspension fork upgrade?
- RT3Sam
Front suspension fork upgrade? was created by RT3Sam
Has anyone done a Front Fork upgrade that works well off road? Id like to upgrade my suspension and I'm able to find good shocks, but can't seem to find anything for upgrading the front forks.
05 Oct 2020 17:36
Replied by RT325 on topic Front suspension fork upgrade?
Could use later DT250 fork up until the went leading axle. Well you could use leading ones but would need the triples due to the different offset but then they hit the tank on full lock. So yes last of the straight axle would be good, maybe "78--ish. Just had a look & "79 goes leading axle. & talking leading axle if ya wanted to go that way the early TT250 forks are nice--forks & triples. I had XT250 early forks on my DT1. Were ok but not as nice as TT250 which are also a mm bigger but better movement too. Mine had "or has" a pretty rough tank on it so just whacked some perfect shaped dents in the tank by smacking the forks around--"rough B-stard" lol.
05 Oct 2020 17:52
- bluntz465
Replied by bluntz465 on topic Front suspension fork upgrade?
Just have to move the stops,whats the big deal?
1982 Yamaha IT465J
1982 Yamaha IT465J
05 Oct 2020 18:04
Replied by MarkT on topic Front suspension fork upgrade?
Race Tech makes emulators for pretty much all forks... tunable and seem to work good to me.
The following user(s) Liked this Post: Bigdog302, nhsteve, RT3Sam
05 Oct 2020 18:10
- bluntz465
Indeed,but I wonder just what is expected of an upgrade . Plushness or stability? Quite a vague target. I cant see him clearing triples.
1982 Yamaha IT465J
1982 Yamaha IT465J
05 Oct 2020 18:22
- JGersh
Replied by JGersh on topic Front suspension fork upgrade?
I second Marks reply. Race Tech gold valve with proper springs and oil...
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
The following user(s) Liked this Post: Bigdog302, RT3Sam
05 Oct 2020 19:43
- RT3Sam
Replied by RT3Sam on topic Front suspension fork upgrade?
So I looked at Race-Tech and it doesn't look too bad. around $400 if I do the work myself. Anyone had any experience installing the springs and emulators in their bikes? With that and a set of Ikon shocks on the rear, may make the bike more manageable in a cross country race.
06 Oct 2020 12:18
I've done it to three of my bikes that I can remember... maybe 4. Had Canon Racecraft make springs for one. Used shortened stock springs on another (less coils = higher spring rate but have to make sure you don't cut too much and get into coil bind)... can't remember others...
Drill press is handy to drill out the damping rod hole as needed but other than that, pretty easy. Their Tech Support by phone is excellent too.
The following user(s) Liked this Post: RT3Sam, husky250
06 Oct 2020 12:37
Point is--if ya move the stops to stop the forks hitting the tank then you end up with a bigger turning circle similar which is damn annoying doing 3 point turns in the driveway. Ended up with a plastic xr tank on mine which gave clearance.
Can't find a still pic of mine but here's a video & can see the RM or PE forks on it. Oh, & i forgot, i now have an AT1 tank which looks like original but smaller & gives clearance on full lock. Did have an XR plastic tank. She's a bit like an AXE with a new head & a new handle--i never quite know what state its in lol. Motor's pretty tweaked--ie Hand Grenade & one hand on the clutch.
The following user(s) Liked this Post: MarkT, 2fishkev, Bigdog302, YZBill
Here's a side shot i finally found on photobucket showing the forks.
The following user(s) Liked this Post: MarkT, Bigdog302, FrankC, JayB, Snglsmkr, DaveHunter, Von, RT3Sam
06 Oct 2020 16:51
