RT1 1970 barrel/jug piston and head
- Tinker man
RT1 1970 barrel/jug piston and head was created by Tinker man
good even in all,
it’s been a little while since I posted anything as it’s been a busy time for me with various personal issues but I am back in the garage albeit in a limited fashion.
my ‘70 rt1 project is a labour of love and I try to work stuff out where I can but I could do with some input from you guys please.
my original barrel and piston are not the worlds best although serviceable in terms of compression. I have procured cheaply another barrel piston and head in better condition but am unclear of what they actually are. The head appears identical externally to mine stamped 275.
the piston seems to be stamped 76 and inside the skirt it says Yamaha Izumi 4. This I have checked on line and it seems to indicate 4th oversize. Not worried about that as I won’t be doing thousands of miles on it. So this seems ok
the barrel/jug has no cutaway machining for a decompressor and has the correct inlet type (non reed). The fins are great on head and barrel. But. There are no cc numbers in the casting and everything I can see online has the cc stamped.
is this a common thing or is it an indication of a different barrel type? MX perhaps?
could someone shed any light? Ideally I need to know I am ok to use all three items on my enduro. I can take more photos if it helps. Sorry if I am being thick and missed something obvious already on here.
hopefully the link works to the pictures.
thanks as ever for your time
ian.
share.icloud.com/photos/008U2_5u6lVPEg0KdHh2vPRNw
ian.
I love taking stuff to bits - putting back together is another thing altogether.
16 Jun 2026 08:39
- Enduro nut
Replied by Enduro nut on topic RT1 1970 barrel/jug piston and head
The 275 stamped head is a 70-71 RT1 360 enduro head. If you look up the part number on partzilla or babbitts you'll see the enduro part number starts with 275 where the M part number starts with 284.
As for the cylinder i don't think its an M cylinder because the fins just don't look to be cut back to clear the GYT pipe. 68-71 Yamaha used GYT kits, it wasn't until 72 when they came out with a true MX bike.
Are you sure its not a 250 cylinder? measuring the bore will determine that.
Im probably wrong on this but if that is a 360 cylinder, i believe the 1970 model had the retard mechanism on the flywheel so Yamaha didnt put a decompression release above the exhaust. Ive heard they did that only in 70 but ive also heard that was only done in 71? and that they both had the decompression releases still. Hopefully someone here will know more about that but right now im thinking you have a 250 cylinder.
16 Jun 2026 09:09
- Tinker man
Replied by Tinker man on topic RT1 1970 barrel/jug piston and head
Thanks for the swift reply enduronut. I agree the 70 didn’t have the decompressor. Hence why I thought it was an indication it was the right one for my year.
I don’t have a super accurate micro meter but a cheap slide rule one which isn’t really big enough. But the piston measures over 80mm but under 81mm on the skirt as best I can see. I was assured the piston barrel and head all came off the same engine. I think the piston measurements indicate 360
If the barrel had the cc size on it I wouldn’t have queried the set up.
When I take the existing ones off the bike I will be able to compare everything including ports etc.
Does that help?
Many thanks
Does that help?
Many thanks
16 Jun 2026 09:18
Replied by MarkT on topic RT1 1970 barrel/jug piston and head
Are you sure piston isn't stamped "75"? That would be 3rd over and oversize is stamped on top.
You could measure the port heights and compare them to yours. 1970 RT1 did not have decompressor, that feature started in 1971. 1970 would have had the advance mechanism in the flywheel to retard timing for starting instead of compression release.
P.S.The above is general. Check your VIN to identify model year. But even then if you have a model that was originally sold outside the USA, sometimes features and paint colors varied. For example, Japanese market models sometimes got features and paint scheme a year early.
The following user(s) Liked this Post: Enduro nut
16 Jun 2026 09:34
I type too slow. LOL
I wanted to add something... Yamaha did sell "MX" (aka "M") models before 1972 and the "off road only" prepped version you could buy at the dealer did not always come with a "GYT" cylinder. In the early years, they actually had 3 cylinders for many models. Enduro, MX, and GYT.
16 Jun 2026 09:46
- Tinker man
Hi mark.
I do have a 1970 RT1. Vin and flywheel set up as you say.
My issue is with the pictured barrel piston etc that I have bought separately. I was told they were off a 70 rt360. The piston could well be a stamped 75 now I look again. I have added a new photo to my link. It’s just the fact there is no CC number stamped on the barrel
I will check and compare the recently acquired one against the barrel on it when I remove it. I just wondered if forum wisdom would say “aaah…. No CC stamp means xxxx”
Don’t want to waste your time.
share.icloud.com/photos/061-S_Yrg-aBvUUVVbESAEe2Q
Cheers for the input.
16 Jun 2026 09:55
3rd over piston.
There could be something about the displacement missing that means something. I don't know what it is though. My guess is "early production"? Lots of experts on here, hopefully one of them has an answer.
16 Jun 2026 10:35
- Tinker man
Thanks a lot mark. Hopefully all will be ok when I compare. It’s in really nice condition even if on third bore.
And was a nice price. Which always helps.
Cheers
Cheers
16 Jun 2026 11:28
- Enduro nut
I thought that was the case regarding the 1970 not having decompression release and having the mechanism on the flywheel. Thanks for that info Mark!
I do have a few of those 70-71 RT360 cylinders laying around. If i remember in the morning ill check them out to see if the CC is stamped or not and report back.
16 Jun 2026 21:11
- Tinker man
That’s great enduronut
Thanks very much.
I will also update when I remove the original items
Cheers
Thanks very much.
Cheers
16 Jun 2026 22:12
