Restoration parts sources?
  • Bp299
  • Bp299's Avatar Topic Author
Restoration parts sources? was created by Bp299
So, I dove down the rabbit hole and framed by bastardized 69 CT1 and would like to do a full resto on it.I plan on going completely thru the motor, blasting the cases, stripping the wrong colors off and painting/powder coating back to OEM.  Also, want to replace all cables, bearings, and other wear parts. Other than ebay, any other good sources for parts? Sources for good painters for the tanks? In the US or?
Here is the before pic of the batmobile.
www.yamaha-enduros.com/index.php/forums/...discussion/19039-why
Last edit: 30 Jun 2023 17:51 by Bp299.
29 Jun 2023 11:23 #1
Replied by MarkT on topic Restoration parts sources?
KDI Reproductions
Clauss Studios
2 Brothers Painting in Oklahoma.
P.S. "Powder coating" was never "OEM" on that model.
The following user(s) Liked this Post: nhsteve, Ht1kid
29 Jun 2023 11:38 #2
Oh, and don't forget YAMAHA! Many overpriced "rare" NOS parts sold on ebay are still available new from Yamaha.
The following user(s) Liked this Post: swm, Ht1kid
29 Jun 2023 11:39 #3
  • Bp299
Replied by Bp299 on topic Restoration parts sources?
Thanks, yes, I check Yamaha first for sure.
29 Jun 2023 12:10 #4
Replied by Gr8uncleal on topic Restoration parts sources?
 from near Salisbury, UK.
In addition to info shown in previous posts, I use CMSNL for reference (some useful photos there) and parts - in the US you have Partzilla, amongst others.
For both CMSNL and Partzilla, if you select a part number and scroll down, other models that also used that part are shown, so don't limit your fleabay search to just your model. Neither list shows every fitment, as neither site has every single parts list on their database.
I have had great success in my own search for small parts in buying job lots - keep what you need and sell on what you don't.
Don't forget to replace the brake shoes, still available from Yamaha.
29 Jun 2023 12:19 #5
  • Bp299
Great sources, thanks.
Yambits seems to have good prices and selection also.
Couple specific questions:
Does anyone make steering stem bearings other than the balls?
Source for an OEM or similar carb?
Does anyone restore the gauges?
What are the correct paint colors/codes Californian Orange and the silver for fenders?
Also, how do you know if the oil injector is working properly? Asking for a friend who may have seized his. :0
Last edit: 30 Jun 2023 07:50 by Bp299.
29 Jun 2023 19:17 #6
I think that All Balls do tapered head bearings, but the upper races are likely too high/tall. Some have fitted tapered lower and standard upper but, personally, I'd stick with standard. The races are available from Yamaha and I get the ball bearings from a bicycle shop.
Fleabay, or a wanted advert on this forum, is your best bet for an oem carb. Is yours missing/damaged?
If you're in the US, then DEET here on this forum restores gauges (or you could buy used replacements). If you're in the UK, I have a contact on another forum who offers this service.
There are instructions in the Yamaha Service Manual (see Tech Library) on how to check the oil pump.
29 Jun 2023 23:48 #7
  • Bp299
So just replacing the ball bearings is typical?
Any other painter sources? 2 bros want $1500 for the paintwork.
Also, best source for piston kits and other engine parts, bearing & seals other than Yamaha?
30 Jun 2023 11:05 #8
Replied by Clegg on topic Restoration parts sources?
Replacing the ball bearings and new grease is the way to go if you want all original. The tapered bearings are great but as mentioned you usually have spacing issues at the top.
I believe Enduronut on here has access to pistons/rings.
PM me on paint.
What is your approximate location? That will help if a member is local to you.
The following user(s) Liked this Post: Bp299
Last edit: 30 Jun 2023 12:30 by Clegg.
30 Jun 2023 12:29 #9
Replied by Ht1kid on topic Restoration parts sources?
Bp All Balls has the good crank seals and crank bearings at a good price that’s who I buy from
30 Jun 2023 15:01 #10
