Tightning Case Screws
- rodss67
Tightning Case Screws was created by rodss67
Feel kind of dumb asking this question but what is the accepted method of tighting crankcase cover screws. Hand tighten with the correct jis driver or tighten with screwdriver and 1 hit with impact driver. Thanks!
The following user(s) Liked this Post: Steve F
20 Dec 2022 17:31
- 1971DT250
Replied by 1971DT250 on topic Tightning Case Screws
Not a dumb question. I hand tighten with a JIS screwdriver. If the heads are worn I replace with new. Never had one come loose. I use a hand impact driver to loosen them if necessary.
The following user(s) Liked this Post: rodss67
- bart.ives
Replied by bart.ives on topic Tightning Case Screws
I have never had to use an impact driver to tighten any of the screws on any of my Yamahas. Not recommended by anyone I have ever known in the past 50 plus years. Blue Loctite and hand tightening. Of course, make sure you use Yama-bond 4 to seal the cases.
Be Happy!
The following user(s) Liked this Post: Steve F, rodss67
20 Dec 2022 17:45
- rodss67
Replied by rodss67 on topic Tightning Case Screws
So I should put a dab of Loctite on the screws?
The following user(s) Liked this Post: bart.ives
20 Dec 2022 17:58
- bart.ives
Replied by RT325 on topic Tightning Case Screws
I'll be different then. I just do them up tight with a T-bar handle using a nice new impact tip that fits good. I go around them a couple of times. I don't use locktite.
The following user(s) Liked this Post: Steve F, AirborneSilva, Ht1kid, msavitt
20 Dec 2022 21:48
Replied by Ht1kid on topic Tightning Case Screws
I’m with Morley T handle and no locktite
20 Dec 2022 22:34
- bart.ives
If you are having issues with tightening the screws on your Yamaha, you need to make sure you are using JIS screwdrivers and screwdriver bits. Regular Phillips screwdrivers do not fit well. I do like the Vessel JIS Ball Grip Drivers.
Be Happy!
The following user(s) Liked this Post: Steve F, Camp3, Pedalcrazy, hackman101
21 Dec 2022 05:30
- hackman101
Replied by hackman101 on topic Tightning Case Screws
After working on my ride and reading this post, I looked up the differences between JIS and Phillips head screws. Now I know why the screws so easily cammed out on my prior bikes. The grind of each type of screwdriver makes all the difference.By the way, I never used any thread locker and have never had any trouble with screws backing out on the outside of the case. In the past, never on the inside either. But when I worked on the inside of the cases of my ride this time, when it came to tightening screws on the inside, I used thread locker.
Also found that JIS screws have a dot stamped on the head, and Phillips do not. The dot is on the top of the screws, in the corner where the cross comes together.
1973 MX250
1964 Honda 50cc C110
1960s Yamaha 65cc scooter
The following user(s) Liked this Post: bart.ives, Sneezles61
21 Dec 2022 06:47
- automan
Replied by automan on topic Tightning Case Screws
#1 NO Loctite.
#2 Phillips were designed to cam out to avoid over torquing.
cliff
cliff
22 Dec 2022 02:48
